Old 08-05-2008, 09:01 PM   #1
atrain0007
atrain0007 is on a distinguished road
Default Fuel Related startup issues.
97 SL1 SOHC.
Im getting a problem after running the car for a while. It doesnt want to start up again after its been up at operating temperature for a while. It cranks and cranks for 5 seconds or as long as I'll let it and never feels like its getting the fuel it needs. If I stop turning the key and then try again it fires right up.
This has been the story for a long time (years). I feel like its a fuel issue because I've been through the entire ignition system recently. It was diagnosed once (by some mechanic) as the fuel filter, but I replaced that and the symptoms never changed.
Fuel Pump? TPS? I come to the experts. Thanks in advance.
atrain0007 is offline   Reply With Quote
Old 08-05-2008, 09:42 PM   #2
TvSteve
TvSteve is on a distinguished road
TvSteve's Avatar
1999 SW2
Default Re: Fuel Related startup issues.
My 97 wagon does the same thing. Here's Squareback's answer to your problem;
It's a fuel pump problem common to 96 and 97 S Series cars. Not detrimental to anything. Do this next time you start your car---turn the key to the "on" position and listen for the fuel pump. Once you hear the fuel pump click off, start the car. The fuel pumps in those cars have a tendency to bleed down pressure after being shut off, so rather than the system being at pressure and ready to start immediately, it has to repressurize before it will fire up. IMHO it isn't worth replacing a working fuel pump because of a 2 second anamoly when you start it. My sister's '97 SL2 has the same problem, I just taught her to prime the pump before starting the car. No big deal really. A Tune up is a great idea, but it isn't going to have any effect whatsoever on an fuel related problem.
Use the search function and you will find many threads on your problem.
Steve
TvSteve is offline   Reply With Quote
Acceleration issues related to ESC/Traction Control GulfBreezeFL Aura General 6 01-07-2012 10:52 PM
91 SL2 DOC: fuel related issue?? alisa S-Series Tech 1 06-08-2008 08:32 PM
Best gas mileage ever, and related issues. mgordon1100 S-Series General 28 01-01-2008 10:16 AM
A/C Compressor check and other related issues SaturnSantory S-Series Tech 21 05-16-2007 12:35 AM
'93 SC2 - No start condition - fuel related? hrsepwr2 S-Series General 6 01-08-2006 11:41 PM
