Old 11-10-2006, 04:01 PM   #1
irondiezl3
irondiezl3 is on a distinguished road
Default water wetter in overflow
added water wetter to overflow i couldnt find a place in radiater to put it will it ever get into the system over time or is it just gunna sit in the tank forever?
irondiezl3 is offline   Reply With Quote
Old 11-10-2006, 04:27 PM   #2
WingsOfSaturn
WingsOfSaturn's Avatar
Default Re: water wetter in overflow
Try writing that again. Hard to understand what you are asking. Periods are your friend
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 11-10-2006, 04:41 PM   #3
irondiezl3
watter wetter is a product you add to antifreeze wondering if it will ever get into my entire cooling system from the overflow tank? or is it going to sit in the overflow tank forever?
Old 11-10-2006, 04:56 PM   #4
Darcane
Darcane is on a distinguished road
Darcane's Avatar
2004 VUE 2.2L
Ugh, still a little hard to read. Most people don't like having to decipher your question, so they will just ignore it. Proper use of punctuation and capitalization goes a long way when seeking advice on a public forum. Fortunately this isn't a long post, so it's not too bad.
Anywho, yes the Water Wetter will eventually get mixed into your radiator. When your engine runs, the coolant gets hot and runs into the overflow container and will mix with the coolant/Water Wetter mixture you have in there. When you turn it off and it cools down, some of the coolant in the overflow tank will get pulled back into the radiator. So it will take a while (months?) but it will get mixed.
Mike
Darcane is offline   Reply With Quote
Old 11-10-2006, 05:48 PM   #5
IronD -> English translation: I added a product called "Water Wetter" to the cooling system through the coolant "overflow". I wonder, since there is no radiator cap, whether it will indeed mix into the cooling system.
Answer: That is NOT an "overflow". That is the coolant reservoir. It is part of the pressurized cooling system. That cap is a pressure cap, like its counterpart on cars with radiator caps. (On cars with radiator pressure caps, the "overflow" is at atmospheric pressure, and the overflow cap is not a pressure cap.) Coolant flows through that reservoir at all times as the engine runs, not just at certain pressures/temperatures. So, the appropriateness of using such a product (and whether it's being used in place of some proper cooling system repair/maintenance) aside, yes, it is now part of your coolant mix.
Old 11-10-2006, 06:02 PM   #6
WingsOfSaturn
Now that makes perfect sense.
95 SL2 MT 220K+
Old 11-10-2006, 06:07 PM   #7
irondiezl3
Thanks! One last question. Where is the throttle body and is it a easy job to clean it? Severeal shops told me mines clogged bad. I do have a rough idle with all new ignition parts so maybe they werent trying to take me for my money?
Old 11-10-2006, 06:07 PM   #8
irondiezl3
Old 11-10-2006, 06:12 PM   #9
irondiezl3
my bad on punctuation
Old 11-10-2006, 06:15 PM   #10
WingsOfSaturn
Since you are in the S-Series we will assume that you have one. By the way, last post was much, much easier to read.
Find your air cleaner, follow that big round plastic tube back towards the firewall. When you run into metal that is your throttle body. You should be able to see the butterfly valve when you have that big plastic tube removed.
Two ways to clean it.
1. Remove it and make it shine.
2. Get a can of intake cleaner and go to town.
95 SL2 MT 220K+
Old 11-10-2006, 06:16 PM   #11
colonelhogan44
colonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of light
colonelhogan44's Avatar
Just get some carb cleaner and a toothbrush and have at it. When you are finished, let it sit for a few minutes to let the cleaner evaporate a bit, and then start the car. Don't worry when it starts hard and or runs crappy for a little while.
colonelhogan44 is offline   Reply With Quote
Old 11-10-2006, 06:38 PM   #12
irondiezl3
Besides plugs, wires, coil pack, air filter and throttle anything else to make a smoother idle? 1996 sl1
Old 11-10-2006, 06:41 PM   #13
WingsOfSaturn
I have to ask, sorry! Have you checked/changed your ECTS?
95 SL2 MT 220K+
Old 11-10-2006, 06:47 PM   #14
westwind999
1999 SW1
Do I get to be the first one to say "change the ECTS (Engine Coolant Temp Sensor)"? The newer brass ones are much better than the older plastic ones.
Old 11-10-2006, 06:48 PM   #15
westwind999
1999 SW1
Dang he beat me!
Old 11-10-2006, 06:50 PM   #16
WingsOfSaturn
I could not resist.
95 SL2 MT 220K+
Old 11-10-2006, 06:54 PM   #17
irondiezl3
that just went bad last month had new one put in along with new wire harness
Old 11-10-2006, 06:55 PM   #18
irondiezl3
maybe it's not as smooth because its in my cold air intake maybe that has something to do with it?
Old 11-10-2006, 07:09 PM   #19
RangerRover
RangerRover is on a distinguished road
RangerRover's Avatar
1999 SW2
Make sure you are not using platinum plugs. Change your ECTS (check the how to forum, instructions for all of this there). Check/clean the coil packs (and bolts holding them). Clean the throttle body. You have hit most of the major locations.
You can tell Linux is made by geeks.
RangerRover is offline   Reply With Quote
Old 11-10-2006, 07:21 PM   #20
WingsOfSaturn
The ECTS is in the head, that is a IAT sensor in the intake. Same sensor though. But it is usually OK to have the old plastic one for the IAT.
95 SL2 MT 220K+
Coolant overflowing through cap on overflow reservoir help! Water pump questions. demoncamber S-Series Tech 85 09-07-2017 05:01 PM
Fuel Overflow Problem cam Vue General 0 11-01-2009 04:09 PM
overflow container MuniMan S-Series Tech 2 01-21-2008 01:42 PM
Water Wetter Question piratepress Miscellaneous Tech 8 06-19-2002 03:39 PM
Water Wetter kev99sl General Saturn Discussion 11 04-27-2001 04:22 PM
