Old 07-14-2021, 02:06 PM   #1
Bill Murray
2007 ION-2 Quad Coupe
1997 SC1
Default Occasional P0172 (too rich) ... suggestions?
This is on a 2007 2.2 engine with automatic...130,000 miles
recent plugs and air filter
engine runs great
after reset may come back anywhere from 100 to 1000 miles accum
thanks for any experience
Old 07-15-2021, 01:04 AM   #2
Default Re: Occasional P0172 (too rich) ... suggestions?
Can you connect a reader to log data, save it or write then down then post them? If you can, log cold engine data with ignition on engine off then log a second set of data after the engine's warmed up. Important data will be coolant temps (cold ambient temps/hot running temps), map, intake air temp (cold), maf sensor.
Old 07-17-2021, 03:55 PM   #3
Bill Murray
1997 SC1
Thanks. Will update with data in the future...my daughter has the car now and it's 40 miles distant.
Old 07-25-2021, 07:47 PM   #4
Bill Murray
1997 SC1
This is looking like a vacuum leak with occasional P0442s so we'll look at the fuel tank cap and evap canister solenoid valve and see if the P0172 goes away too.
Old 07-27-2021, 09:57 PM   #5
bern
2006 ION-2 Sedan
The canister purge solenoid valve (by valve cover) maybe leaking, disconnect the solenoid valve wire connector and hose that goes to the back of the vehicle, with the engine running no vacuum should be felt from the back end of the solenoid.
Old 07-28-2021, 02:10 PM   #6
Bill Murray
1997 SC1
Thanks, will check. I only see the car a couple times each month so it may be a couple weeks.
Occasional sputter, rich fuel flamin-gitaur L-Series Tech 9 04-23-2015 11:31 AM
P0172 System Rich Trans Man S-Series Tech 17 02-07-2010 08:40 PM
Another P0172 rich fuel alordofchaos S-Series Tech 14 09-15-2009 02:30 PM
P0172 rich code ecraw L-Series Tech 4 07-16-2008 06:30 PM
96 SL2 runnig rich P0172 mulder1fx S-Series Tech 9 05-07-2007 10:37 AM
