Old 12-12-2011, 09:32 PM   #1
dddaaa
dddaaa is on a distinguished road
Default 97sl1 water leak at pipe below overflow reservior
The hose beneath the overflow leaks. The water is coming out from the metal or where the hose connects to the metal t connector that goes to where you put water in (overflow resevior). There is a large rubber hose that seems to be perminately attached to this metal t connector. Does anyone know how to fix this problem? I am not sure if it is leaking from this permanently attached hose (think it is) how to fix the problem. Do I need to get the entire metal connector say from a junk yd? If so I am not sure how to remove it since it goes towards the firewall and is kinda long.
Also, can I patch this somehow with some cement?
dddaaa is offline   Reply With Quote
Old 12-13-2011, 06:16 AM   #2
Default Re: 97sl1 water leak at pipe below overflow reservior
Post a picture of this leak. A possible repair may be done by replacing the hose - carefully slitting and peeling back the crimped portion of metal that acts as a clamp over the inner portion of tubing that's inserted into the hose. Once the crimped part is peeled away and cut off the old hose can be pulled off for replacement. This way the aluminum fitting is retained and worm clamps used to clamp the new hose inserted over the metal tubing. I recall a member doing this in a past post.
VCX NANO
Old 12-13-2011, 11:32 AM   #3
dddaaa
I do not have a camera to take a pic. I think the leak is either coming from the hose that goes into the alumnium t fitting from the reservior or from under the clamp on the other hose. Can not see for sure as it drips at the bottom. I might just get a new clamp and tighten tight and see if that fixes it. I do not understand how to slit and peel back the crimped portion of metal u are talking about. So you are saying I do not need to go to junk yd and get the metal thing that is below reservior that goes towards the firewall? (good as it looks very difficult to replace).
I can not see how there would be a hole in the metal (alumnium at the bottom) as there is no wear there or salt or anything. If there is, is there some cement that seals alumnium or tape or something?
I see no holes in the rubber hoses or anything either.
Coolant overflowing through cap on overflow reservoir help! Water pump questions. demoncamber S-Series Tech 85 09-07-2017 05:01 PM
water from exhaust pipe xybaby S-Series Tech 2 01-01-2009 12:03 AM
Shake front end and water pipe bklyn87 L-Series General 3 01-31-2007 02:11 PM
water wetter in overflow irondiezl3 S-Series Tech 21 11-11-2006 05:04 PM
Water at the exhaust pipe? HPINitro S-Series Tech 27 11-24-2003 10:54 PM
