#1 |
Is this a worthwhile 130K mile maintenance item?
Wide price range - Any brands to avoid? |
#2 |
![]() Join Date: Jul 2002
[QUOTE=DonP]Is this a worthwhile 130K mile maintenance item?
W ide price range - Any brands to avoid?[/QUO I did mine at 103k |
#3 |
Do whatever Uzzy says (if he doesn't reply soon, PM the lazy *******).
#4 |
Now I remember,I used a Dayco brand with no problems.Some people here will tell you different.Good luck to you
#5 |
![]() ![]() Join Date: Jan 2006
2002 SC1
'95? Use only the Gates OE.
You can get it from the dealer, or sometimes over the net, but make sure it's NOT the aftermarket ![]() ![]() There is no predetermined change interval for tensioners. Belts are 4 years or 40K, I think. Something like that. Go with the Dayco over the Gates aftermarket.
Aut viam inveniam aut faciam ... If your ECTS is not brass...your ass is grass. ... If you have a problem, if no one else can help, and if you can find him, maybe you can hire Uzzy. |
#6 |
At 130k, I'd say it would be good preventative maintenance, and will offer good piece of mind if you change it. Also, it makes good sense to change the belt if you do the tensioner.
On a side note, the belts on Saturns are spooky critters. At 150,000 miles, my car still had the original belt on it, and it still looked good, and was not excessively stretched. That just strikes me as not being natural, but I've seen others with long-lived belts. I changed it out for piece of mind.
Knowledge is power. Power corrupts. Study hard. Be evil. |
#7 |
![]() Join Date: May 2002
Keep in mind, the OE unit will have an arrow guage, from which you'd be able to see if the unit's spring/tension was still within the tension spec parameter.
At night, take a flashlight, and you'll be able to see the range within which the "arrow" should be sitting.
> 95 SL 2 = 653,369 Miles 40.4 MPG, as of 5/20/11. My manual Radiator Fan Switch, courtesy of Wolfman's patient installation guidance, continues to be.......invaluable < The car was retired |
#8 | |
2002 SC1
![]() Quote:
#9 |
Hm, I found the indicator arrow, but not the "range" limit marks. Can you describe where they are? I posted a pic of mine as visible from under the hood; it's here. Uzzy, can you point out where, on the photos, I determine if the arrow is in range? Maybe you can save the photo, mark it up and re-post it? I'm confounded. Thanks, man.
#10 | |
2002 SC1
![]() Quote:
#11 |
![]() Join Date: Feb 2004
2002 SL
1993 SL2
Spend the extra $5 and go O.E.. Bought a Goodyear "Gatorback" and was sorry because of noise, which I assume was due to poor tolerances.
#12 | |
2002 SC1
![]() Quote:
#13 |
![]() Join Date: May 2006
1994 SC1
Six weeks ago I had to install the aftermarket Tensioner and Belt (with the Delco badge) and I was convinced that the whole belt & pulley area was a little more hissy than it used to be when I listen with the hood open. I also believed that there were minor inconsistencies in the pitch of the idle if you sat in the car in Neutral and listend for about 1 minute.
Can't say for sure if it was different or if I was paranoid because of the discredited aftermarket parts. Seems to have gone away now, maybe a new belt needs some miles to break in? I couldn't locate a Gates OEM on time anywhere in Canada. Saturn dealers refused to tell me which part they planned to charge $260 for, so I had the Delco delivered for $140 + $46 Belt. I could have got the whole Dayco package for just $114- but the supplier wouldn't deliver and it would have $40 cab fare. I was to stressed to think of it, but do you suppose I could have bought some $14 5-rib belt which was 4-5 inches shorter and put it on the wobbly Tensioner to move the water pump just enough to limp the car to the parts store, and then to my own mechanic? |
#14 | ||
2002 SC1
![]() Quote:
#15 |
![]() Join Date: Aug 2005
2006 ION-2 Sedan
i just changed my belt tensioner at 160000 miles. also relpaced the idler pulley. both of them had loose and noisy bearings. also installed the new style upper engine mount with new longer mounting studs. old mount had cracked rubber and was causing vibration. took about one hour to change everything. all parts came from saturn. i will not use anything but dealer parts. they always fit and work without any problems.
#16 |
![]() Join Date: Jan 2005
Mine went after 88,000 mile and it was a 96. Is it a common problem for these cars? Weird.
#17 | |
2002 SC1
![]() Quote:
#18 |
does anyone know what size the bearing is? would there be any issues swaping the wheel and bearing from a 2000+ tensioner onto the older ones?
#19 | |
![]() Quote:
#20 | |
2002 SC1
![]() Quote:
Bookmarks |
Serpentine Belt Tensioner Replacement | mberry | S-Series Tech | 2 | 06-03-2009 01:01 PM |
1998 SL1 serpentine belt tensioner replacement | DErkAD | S-Series Tech | 6 | 02-22-2009 05:01 PM |
Serpentine belt and tensioner | brushwood | S-Series Tech | 3 | 06-23-2007 09:29 PM |
FS: Serpentine Belt Tensioner | Scout238 | Classifieds | 6 | 02-17-2006 03:33 AM |
Serpentine Belt and Tensioner | speaker | S-Series General | 5 | 09-08-2005 10:05 AM |
