#1 |
![]() Join Date: Oct 2009
1999 SL
Looking to buy some wheels for my car. Thinking about 17's for my 99 SL. Now im sure they will fit but if anyone is running this setup how do you like it?
#2 |
![]() ![]() ![]() Join Date: Feb 2005
1999 SC1
A lot of people run 17's on S-Series. They're not optimal for performance, but many people like the look. Be sure to get the right sized tires, and it should be fine.
SaturnSeries.net owner |
#3 | |
![]() Quote:
s3aturnr
"reno is a lot like maybury, except everyone's on crystal meth and prostitution's legal" - junior |
#4 |
1999 SL
Those look great btw. Thanks for the opinions! Coming from fbodys and 18's being a median size wheel i didnt know how "dubbed" 17's would look.
#5 |
I like 16s.
#6 | |
![]() ![]() Join Date: Jan 2006
2002 SC1
![]() Quote:
![]() I had another similar set as well. I like them because they were wider, but it was more for looks. They looked better than 15s, but for real performance, keep 'em a little smaller.
Aut viam inveniam aut faciam ... If your ECTS is not brass...your ass is grass. ... If you have a problem, if no one else can help, and if you can find him, maybe you can hire Uzzy. |
#7 |
![]() Join Date: Jan 2008
I have MSR 17" rims on my 97 SL2 and I love them. It handles way better than the 15's and it will not make your car slower.
I'm running 215/45-17 tires and they seem to be about the right size for the SL. Go for the 17's you won't regret it. |
#8 |
![]() Join Date: Nov 2009
I have a 97 Sc2 I don't know if sl wheel sizes are the same but I assume they are. However anyways I have Tenzo R Av-7's which is a 17 in. rim with yokohama 205/40/zr17 tires and they matched up almost exactly to the stock wheel height. So I hope that helps...
#9 |
1999 SC1
If the 17's are heavier than the 15's (they usually are), then it will make the car slower. But, most drivers won't ever notice the difference. Someone who autox's, etc, will notice.
#10 |
1999 SL
Thanks for the advice guys
#11 |
![]() Join Date: Jul 2008
2002 SL1
Cant go wrong with a decent set of 17s as long as they are not some 5 year old design that is heavy, the modern 17s you find from name brand wheel manufactures weigh no more than 1-3 pounds more than 15s. Better look, better grip, and a nicer ride with 17s!
2002 Sl1 5 Speed Spring Special Eibach Pro Kit ST-Struts XXR-001 17in Rims Falken 205/45/17 Tires Tint and Clear Corners Thermal R&D Cat-Back! |
#12 |
1999 SC1
has nothing to do with age - just check the weight before you buy if you care about it. There are lightweight wheels that are older, there are freaking heavy wheels that are brand new. Truly lightweight wheels are going to cost more money, but you can get middle of the road weight for reasonable prices.
#13 |
1999 SL
My SL is silver with the primer bumper. I understand everyone has they're own taste and i know i have to get something that "I" like. With that out of the way, what color do you guys think will go best? All black, black with chrome lip, gun metal, that grey BMW shade, all chrome? The primer front and rear bumper are really throwing me off on a decision.
#14 |
I noticed going from 15.0 lbs 16x7 to 12.8 lbs 15x7 wheels with Hankook R-S2 tires mounted on both sets. the steering felt better and the car would change direction quicker on the 15s. less unsprung mass is better.
eRic 02sc2 DR SCCA Solo 2001,2002 1st DSP WHRRi 2007,2010 Fun Run 1st DR SCCA 2008 Triathalon 1st PF DR SCCA Solo 2009 2nd ST DR SCCA Solo 2010 1st ST Crutchfield: pkeqe-6j8e3-d2qqe |
#15 | |
2002 SC1
![]() Quote:
I had white wheels on silver and I don't commend it. ![]()
#16 | |
![]() Quote:
i am 100% sure of the following: on the s-series saturns, all else equal, a 15" wheel/tire combo will beat a 17" wheel/tire combo EVERY SINGLE TIME on a road-course race track. the grip with a 15" wheel is more linear, gives more feedback to the driver and is a thousand times easier to balance on the edge of traction than a 17" wheel. believe what you want. but if you don't know, don't say... s3aturnr
#17 |
1999 SL
Again guys im not looking for performance or coming out of a corner flater and faster. I bought this car as a good gas milage DD, i have zero intenions on making this car perform other than getting good mpg's. Just want it to look sharp. Sorry no knowledge on autox here. Im a straight line guy lol, grew up at milian and lapeer dragways here in SE michigan
#18 |
![]() Join Date: Jul 2006
I think some 17x9s with the 245/35R17 Toyo R1Rs would probably handle pretty well. It would be extra rotational mass compared to 225/xxR15s, but the gearing isn't bad. Getting the right offset so they actually fit might be tricky, and they may not be worth it with a stock engine. I am happy with the 205/50R15 V710s since I am stuck with 15x6 rims, but I don't run them on the street. My 225/45R16 Hankooks are nice street tires.
1995 Saturn SC2 - ST(X)ish 1994 BMW 325i Sport www.furrin.org |
#19 |
I have 17's. If I were to do it again, I'd get 16's. You'll notice a big difference in handling with the wider tires. As far as performance goes, you'll need a little extra to push them, but it's not that big of a deal.
2000 SL2 5-speed turbo MSnS-E fuel & spark controlled @ 17-20 psi (methanol injected) Fully forged, P&P head and manifolds, FSR turbo cams, balanced to 9k RPM http://www.cardomain.com/ride/3070918 |
#20 | |
![]() Quote:
Bookmarks |
Just got some 20 inch rims, tire pressure? | mangler66 | Vue Mods | 4 | 05-11-2007 01:29 AM |
20 inch rims on an 04 Redline | 04RDLN | Vue General | 15 | 04-13-2004 11:39 AM |
FS: 16 inch rims/tires | saturnhawaiiguy | Classifieds | 2 | 10-19-2002 08:31 PM |
L-Series 16-17 inch rims? | kenglover3 | Mods and Performance | 6 | 11-30-2001 06:32 PM |
14 inch rims on a LS1? | Andre | L-Series Tech | 2 | 09-26-2000 07:38 PM |
