Old 06-28-2022, 04:36 PM   #1
GTSRider
GTSRider is a jewel in the roughGTSRider is a jewel in the roughGTSRider is a jewel in the roughGTSRider is a jewel in the rough
Default Right Rear Frame Spring Mount Rotted Rust
While rotating tires this morning on my 03 ION , I discovered that passenger, right rear top spring mount is rotted to the point that, it is barely holding spring. The only fix is to cut our rotted 6-8 inch section , and weld in new section from a donor car , or have a fabricator build one out of box steel.
I would junk the car, but I just put in new front control arms , bearings , rotors, calipers, and on , and on , so car runs great , with nice cold ac..... Anyone ever run into this ? GTSRider, Hudson Valley , NY
GTSRider is offline   Reply With Quote
Old 06-28-2022, 05:12 PM   #2
Bill Murray
2007 ION-2 Quad Coupe
1997 SC1
Default Re: Right Rear Frame Spring Mount Rotted Rust
Sounds like it's worth fixing. But I'd look closely at other parts of the structure also like the subframe attachments to the unibody. And of course the rear spring mount on the opposite side.
If you can afford it, buy a cheap wirefeed MIG welder and learn how to use it. Not difficult and you'll be quite popular with your friends and neighbors when word gets around.
Frame rust 2005TealSaturn Vue General 18 03-14-2021 08:21 PM
I see some serious sub-frame rust raymondjiii S-Series Tech 3 04-22-2018 10:25 PM
Time to replace another rotted out trailing arm mount. junker S-Series Tech 0 05-10-2017 06:18 AM
RUST HOLE! in the FRAME of my 94 sl1 trooper94 S-Series General 3 12-02-2011 10:34 AM
K-frame rotted heathcom S-Series General 9 11-14-2005 08:25 AM
