Old 06-08-2022, 06:42 PM   #1
JosephN79
JosephN79 is on a distinguished road
JosephN79's Avatar
2004 VUE Red Line
Default Water in driver side floor
Im getting water in the driver side floor board after rains. Itís not coolant, and it happens just sitting in the driveway.
I looked today and saw where water was still present as it trickled down the gray trim near the hood release.
Iíve heard this can happen from the vent drain holes where the wipers are as well as sunroof drain hoses?
The sunroof was closed the whole time.
Thanks
JosephN79 is offline   Reply With Quote
Old 06-09-2022, 12:11 AM   #2
Mr Toad
Mr Toad has a spectacular aura aboutMr Toad has a spectacular aura aboutMr Toad has a spectacular aura about
Mr Toad's Avatar
Default Re: Water in driver side floor
Sounds like a typical Sunroof drain hose.
2005 Saturn Vue
Front Wheel Drive
3.5L V6 Engine
5AT Automatic Transmission
180,000+ miles
Mr Toad is offline   Reply With Quote
Old 06-13-2022, 01:10 AM   #3
homerec130
homerec130 is on a distinguished road
2008 VUE 3.6L
My 2006 Vue had this as a chronic problem. I got fed up with it and them disconnect the and seal the sunroof. Hasn't been a problem since.
It seems the scrimped on the drain lines and they didn't go all the way down.
Paul "Homer" Simpson
15 Ford Fiesta, Gray
06 Vue 3.5L, FWD, Storm Grey (Wife's Ride)
08 Vue 3.6L, FWD, Sunburst Orange - RIP 6T70
homerec130 is offline   Reply With Quote
Old 06-19-2022, 10:31 PM   #4
newbievueowner
newbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the rough
2006 VUE Red Line
Yup, drain lines would fall apart/disintegrate over time, leading to leaks inside the cab
Saturn Vue: The 250 HP tupperware
newbievueowner is offline   Reply With Quote
Old 07-06-2022, 11:05 PM   #5
jrad
jrad is on a distinguished road
2006 VUE Red Line
I fixed all my drain tubes and still ran into never ending leaks.. I finally just sealed up the entire sunroof. water in your car will eventually ruin your vue... you only put up with it so much.
Turns out the sunroof wouldn't fully push it back up anymore and I had a lake in my car..... thats after fixing both drain tubes.
2006 Vue Redline Laser Blue
1994 Camaro z28 Green Metalic
jrad is offline   Reply With Quote
Water on Driver's floor SeaRayCapn 2008 Vue 4 06-19-2018 10:15 PM
Water on LS2 driver side floor sherrvt L-Series Tech 1 10-21-2010 07:59 PM
Water on the driver floor Garb L-Series Tech 10 10-19-2008 09:52 AM
Wet Driver's side floor Help please!! jimpennjr S-Series Tech 2 09-20-2006 10:27 AM
95 SC2 water in floor on driver side hpneon S-Series General 1 06-17-2006 03:19 PM
