Old 01-18-2010, 08:38 PM   #1
AndreasChen
AndreasChen is on a distinguished road
Default 02 SC2 Headlight
Hi,
I want to replace by myself the damaged headlight in a hit & run to save some money and I located a 02 SL1. Are the headlights in sedan and coupe exchangable for 02?
Also, what is the doablity for DIY the headlight? Is there any instruction? Richpin doesn't
The Chilton's manual is not good enough either...
02 Saturn SC2, noisy, trying to quiet it down...
AndreasChen is offline   Reply With Quote
Old 01-18-2010, 11:05 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: 02 SC2 Headlight
No. 2001-02 coupe headlamps are not the same as the sedan. you need a 2001-02 coupe headlamp for your 02 SC2.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 01-18-2010, 11:43 PM   #3
AndreasChen
Thank you!
Located a new aftermarket part on ebay motor!
Old 01-19-2010, 12:27 AM   #4
Uzzy
Uzzy has a spectacular aura aboutUzzy has a spectacular aura about
Uzzy's Avatar
2002 SC1
2005 VUE 2.2L
Two bolts.
Don't disassemble the aiming mechanism. And be careful with the bulbs. The easiest way to do it and not damage them is unbolt the broken headlight, unplug the bulbs and leave them in the broken one. Then remove the bulbs, one by one and put them in the new one. Plug them back in and bolt it on. Since you're getting a "new" one (I'm assuming it's from a junk yard) it would be a good time to make sure the vent tubes are clear so you don't get condensation.
Aut viam inveniam aut faciam
If your ECTS is not brass...your ass is grass.
If you have a problem, if no one else can help, and if you can find him, maybe you can hire Uzzy.
Uzzy is offline   Reply With Quote
Old 01-19-2010, 12:46 AM   #5
AndreasChen
Thank you for the details!
I am getting a brand new aftermarket piece so I am not expecting the vent tube to be clogged
Old 01-21-2010, 10:54 PM   #6
AndreasChen
If you happen to be in my situation, avoid this:
http://cgi.ebay.com/ebaymotors/ws/eB...m=110472902857
I put this on and started to aim, then the adjuster broke into pieces
It took almost an hour to take the old adjuster off the broken lamp to fix the new lamp
Old 01-22-2010, 01:35 PM   #7
Uzzy
Uzzy's Avatar
2002 SC1
2005 VUE 2.2L
Wow, that sucks. Why did it take so long to take the old adjuster off? The only time I replaced a broken headlight the new one didn't come with the adjusters and I had to take them off the old lights. But that was on a U-body van. I didn't think the S-series would be much different.
Old 01-23-2010, 12:08 PM   #8
AndreasChen
The screws are not very accessible. I need to rotate them quarter circle by quarter circle...on both...totally 6 screws in this way...
