Old 11-15-2009, 04:28 PM   #21
Phredawgy
Phredawgy is on a distinguished road
Phredawgy's Avatar
1996 SL2
Default Re: Code P0302
Have to go on an unexpected little road trip this morning(thankfully a friend is loaning us their car) so I haven't had time to do a compression test yet.
When I get time I plan on switching the coilpacks to see if the misfire issue switches cyl.......and if I get nowhere with that doing a compression test.....the car has over 260,000 miles on it, and I've had it for almost 100,000 of those and have never changed the fuel filter....could this be a possible contributing factor as well?
The streets will flow with the blood of all the non-believers!!!! And all those who won't include their vehicles vital information in their posts!!!!
Phredawgy is offline   Reply With Quote
Old 11-15-2009, 04:32 PM   #22
The fuel, filter is definitely due. Probably not the cause of the problem though.
Old 11-16-2009, 09:52 PM   #23
Phredawgy
Phredawgy's Avatar
1996 SL2
well swapping the coil packs didn't change the code, it's still coming up as P0302......so does that eliminate the ICM or no? I am not sure how you would test that? I've done a little reading and seen people mention that it could be caused by a faulty injector.....how would you test that? I also just got a look of what I thought might be a problem with the wiring to the ECTS where it was spliced when I changed the old resin one to the brass one....could this also be a possible culprit?
Old 11-16-2009, 10:00 PM   #24
Solder the ECTS connections. Nothing else works. Pull the fuel rail and swap the #2 injector with either #1 or #4 and see if the problem moves. You test the ICM by substitution, get a new one at the J/Y as the aftermarket is both expensive and not reliable.
Have you ran a compression test? Misfires can be a burned valve.
Error Code P0302 Misfire pospo Ion Tech 3 06-26-2009 09:52 PM
Code P0302 help logicspeaks S-Series Tech 6 03-28-2008 09:35 PM
96 SL2 P0302 misfire code mbolena S-Series Tech 5 12-05-2007 03:17 PM
P0302 Cylinder 2 misfire. M.Nguyen S-Series Tech 4 04-07-2005 12:33 AM
P0302 - Cyl. 2 Misfire---HELP 1996SL2 Miscellaneous Tech 2 07-31-2001 02:27 AM
