#1 |
![]() Join Date: Nov 2021
Seems my HVAC module will not adjust either temperature or vent selection. I have tested the blend door actuator and is is good also checked voltage going to actuator and it is good also. I have tried the recalibration procedure and it doesn't work. I have been told the module must be reprogrammed with a GM Tech 2 ....can anybody verify that is correct? Thanks in advance.
#2 |
When testing actuators, did you test them removed from the hvac, reconnected to wiring and adjusting the control panel? Without being physically connected to the temperature or blend door, actuators should move from control panel commands.
Search past threads for a Vue member welcoming email questions, sometimes supplying drawings, wiring diagrams and technical advice. |
Bookmarks |
Tags |
hvac problem, module, reprogramming, tech 2 |
hvac module replacement | docbubba1 | Ion General | 2 | 08-16-2016 03:29 AM |
2009 Vue - HVAC Control Module? | GunnyL68 | Vue Tech | 4 | 01-06-2016 04:23 PM |
HVAC control module 2002 Vue | Wayne Smith | Vue Tech | 5 | 10-20-2009 12:46 PM |
HVAC module/actuator | DanB98TJ | S-Series General | 0 | 07-20-2006 01:17 PM |
Hvac Module? | 9TWOSC | Miscellaneous Tech | 1 | 04-28-2003 11:39 PM |
