Old 01-16-2016, 09:16 AM   #1
SoundGuy
SoundGuy is on a distinguished road
SoundGuy's Avatar
2007 AURA XE
Default Whereto mount amplifier in cargo area?
My order from Crutchfield is in and I'm excited to hook up my new amplifier (stereo and speakers are all aftermarket). I've figured out where I need to run my cables but where I'm stuck is where to mount the amplifier.
I do use the cargo area with seats down from time to time so back-of-seat mounting is out of the question.
There is a spot just behind the back seats, in the spare tire well that might work. But my amp (Alpine MRV-F300) might be a bit to big for that. Not sure.
Where have ya'll mounted your amplifiers and any tricks I should know?
SoundGuy is offline   Reply With Quote
Old 01-16-2016, 10:15 AM   #2
PortugalFocus
PortugalFocus's Avatar
Default Re: Whereto mount amplifier in cargo area?
If you still have the mini spare there's enough room in there to put a small amplifier between the cover up pad and the tire. Alternatively you can cut up the foam a bit and mount it there.
Old 01-16-2016, 10:25 AM   #3
SoundGuy
SoundGuy's Avatar
2007 AURA XE
What do I screw the amp onto? Do I need to built a mount or something? I don't want to mount it directly onto the metal floor - the same place I'm grounding it.
Old 01-16-2016, 01:33 PM   #4
ryan_g
ryan_g is on a distinguished road
2004 VUE 3.5L
Mine is mounted between the spare and the back seat under the carpet. Not sure if your amp will fit there but here are some pictures of my install for a JL Audio 10W3. I used a few small strips of MDF to isolate the amp from the floor and allow airflow. BE CAREFUL. The gas tank is close to that area.
ryan_g is offline   Reply With Quote
Old 01-16-2016, 02:05 PM   #5
SoundGuy
SoundGuy's Avatar
2007 AURA XE
Ryan, thanks for the post with the photos. That helps. I've been digging around my engine compartment and found two ways trhough the firewall. One is a small single entry that already has a single red cable running through it. This one I can access if needed.
The other, with the massive cable bundle, I can't figure out how to access it from inside the cabin. I've unbolted the cover under the dashboard but everything behind it is covered up and appears the gray covering is bolted in from the engine side.
Old 01-16-2016, 02:14 PM   #6
ryan_g
2004 VUE 3.5L
It has been a while since I did mine but I remember there being a grommet with a bunch of wires on the drivers side that I slid the wire through. Wasn't the easiest thing in the world. Ill check later today.
Old 03-21-2016, 09:40 PM   #7
DJCorey01
DJCorey01 is on a distinguished road
DJCorey01's Avatar
2004 VUE Red Line
Not sure if you completed your install yet but there is a good amount of room under the floor if you cut the foam...
DJCorey01 is offline   Reply With Quote
Old 04-02-2016, 11:50 PM   #8
ebenditt
ebenditt is on a distinguished road
ebenditt's Avatar
2004 VUE 3.5L
Question, why not just get a kicker hideaway and just use some quick disconnect(s) for easy removal.
Saturn Vue 3.5L v6 FWD
ebenditt is offline   Reply With Quote
Old 04-03-2016, 01:11 PM   #9
ryan_g
2004 VUE 3.5L
Not sure who this is directed at, but my answer would be that I personally don't like those all in one enclosures.
With a seperate sub and amp I can build a box for whatever frequency range I want and make it to fit my car. Plus I can use my amp on whatever sub I want in case I ever decide I want something different.
Basically my options are open to whatever changes I might want to make down the road for far less money than replacing an all-in-one. I could buy another JL 10w3 for the cost of that all-in-one and in car audio you definitely get what you pay for
Old 04-04-2016, 06:30 PM   #10
ebenditt
ebenditt's Avatar
2004 VUE 3.5L
I got you, I was just suggesting the all-in-one as a space saver.
Old 09-07-2016, 09:51 PM   #11
Indyl03
Indyl03 is on a distinguished road
2004 VUE 2.2L
Could you use anchors to mount amp to foam? Weight would be a limitation tho
Indyl03 is offline   Reply With Quote
Old 09-11-2016, 11:05 PM   #12
ryan_g
2004 VUE 3.5L
I suppose you could make a bracket using the foam as support. It would be kind of difficult since the bracket for the amp needs to be between the two foam sections.
I know my amp isn't really in a pretty amp rack but nobody ever sees it. More of a function>form install.
Some prefer to take sections of the foam out for heavier-duty car stereo setups. I would consider it if I ever go with a 4 channel for door speakers.
Tags
amplifier
Cargo area protection aaronearles Astra General 13 03-24-2009 12:51 AM
Cargo area like a Forester BobbyP Vue Mods 0 08-10-2008 04:57 AM
12 VDC outlet in cargo area David 93 SL2m Vue General 6 07-05-2007 11:28 AM
Rubber Cargo Area Mat for SW? SW2Muck S-Series General 9 11-22-2004 11:16 PM
VUE cargo area MPR2001GTi Vue General 15 07-17-2003 08:01 PM
