Old 11-15-2015, 08:11 AM   #1
renegade734
renegade734 is on a distinguished road
Question I cleaned the battery terminals, now this:
I was dong routine maintenance on my 2008 Aura 3.5 yesterday. I disconnected the battery terminals for cleaning. After reconnecting, vehicle would not crank. Security light is ON, steady, and does not turn off. Cluster/Theft fuse checks out ok. Anyone have any ideas as to what I should look for next?
renegade734 is offline   Reply With Quote
Old 11-15-2015, 09:03 AM   #2
billysvue
2005 VUE 2.2L
Default Re: I cleaned the battery terminals, now this:
Maybe the owner's manual goes over "security particulars" that may be affected with battery removal./replacement...
Doulbe check your work.
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 11-15-2015, 10:03 AM   #3
renegade734
From page 2-19 of the 2008 Saturn Aura owner's manual:
"When trying to start the vehicle if the engine does not start and the security light on the instrument panel cluster comes on, there may be a problem with your theft-deterrent system. Turn the ignition off and try again. If the engine still does not start, and the key appears to be not damaged, try another ignition key. At this time, you may also want to check the fuse. See Fuses on page 5-97. If the engine still does not start with the other key, your vehicle needs service. If your vehicle does start, the first key may be faulty. See your dealer/retailer who can service the PASS-Key® III+ to have a new key made. In an emergency, contact Roadside Assistance. See Roadside Assistance Program on page 7-7."
That's what led me to check the fuse. Protip: If the fuse is blown or missing, the security light does NOT illuminate.
And it will NOT start with either key ...
Looks like I'm gonna need a tow truck ...
Old 11-15-2015, 10:23 AM   #4
billysvue
2005 VUE 2.2L
Did you double check your work? How'd you clean the terminals? Check connection at starter?
What else did you do , maintenance wise?
VOltmeters are cheap- what's the voltage of the battery?
'17 Suby Forester
Old 11-15-2015, 10:35 AM   #5
billysvue
2005 VUE 2.2L
Is there a "security code" mentioned in your owner's manual?
FOund this: maybe "reset and relearn" is needed.
It starts with shorting the (disconnected) batt cables together...
http://www.justanswer.com/saturn/6l6...html#re.v/326/
'17 Suby Forester
Old 11-15-2015, 12:54 PM   #6
billysvue
2005 VUE 2.2L
maybe this applies, as well.
http://www.saturnfans.com/forums/sho...d.php?t=202958
https://cse.google.com/cse?cx=partne...arn&gsc.page=1
'17 Suby Forester
Old 11-15-2015, 05:35 PM   #7
renegade734
Nope ... I am not having any problems with the fobs. I am in the middle of tryng the reset process linked above, and will let you all know if it works.
Old 11-15-2015, 05:46 PM   #8
renegade734
By way of follow-up, the relearn/reset process did NOT work, so I am going to call it a day and try another time.
Old 11-15-2015, 06:48 PM   #9
billysvue
2005 VUE 2.2L
YOu shorted the disconnected battery cables together at the start?
What about battery voltage reading?
'17 Suby Forester
Old 11-15-2015, 07:24 PM   #10
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
hard to believe that with an immobiler key system disconnecting the battery would do anything to keys or security system.
Old 11-15-2015, 08:39 PM   #11
^ I agree. Security, even the latest immobilizer using rfid keys shouldn't go into lock out mode just because a battery needs to be replaced or disconnected for repairs or maintenance.
renegade734, did you try leaving the battery disconnected and physically checking fuses? The ones for the main electronics, ECM and BCM? The bcm has programming for Passlock/Passkey, GM's immobilizer and shouldn't trip over something as simple as battery disconnects. Sometimes power surging when reconnecting battery power can blow a fuse so checking each fuse manually may reveal a blown one.
Old 11-30-2015, 09:13 AM   #12
renegade734
I want to follow up: Sorry I have not gotten back to all of you on this, but I have had bigger fish to fry over the last two weeks. All fuses checked out OK. Replaced battery; still no-start. This makes no sense. Changing battery should have solved the problem. Any ideas?
Old 11-30-2015, 05:49 PM   #13
If security is not preventing starting, there are only a few things to check. Try swapping START RELAY 31 with a similar relay. If this doesn't work, you may have to tow the vehicle to GM to determine what failed. Below are two files, one about security and the other about the starting circuit.
Old 01-07-2016, 10:43 PM   #14
renegade734
As a final follow-up, nearly two months after all this began, the car is finally running. $550 to replace the security control module and two new keys. The replacement module invalidated my three original keys. At least my vehicle is back on the road.
Nearly every situation I have read about within this forum has come to pass with this vehicle. If it were paid for, it would be a cube.
Now, it's off to the dealer to purchase replacement windshield washer nozzles. The one on the passenger side has fractured. I think I will save myself the aggravation and purchase two. But that's another saga ...
battery, no start & no crank, pass-key iii
Loose Battery Terminals edlee S-Series Tech 3 06-01-2012 06:41 AM
terminals A & B hroayls07 S-Series General 2 04-30-2007 09:15 PM
battery terminals cpt.morgan26 S-Series Tech 5 02-25-2007 06:56 PM
Battery Terminals saturnpowersw2 S-Series General 7 06-12-2006 09:45 AM
Battery Terminals Wrong Sizes... Rob1998SL2 Miscellaneous Tech 8 07-20-2004 03:10 PM
