#21 |
![]() Join Date: Jul 2014
2002 SL
I realize for sure that it may be the starter. Just don't want to believe it cuz it's pricey
#22 | |
2002 SL
So I meant, it started up fine 3 times over the course of 6 hours, then wouldn't start. |
#23 | |
2002 SL2 Manual - new in November, 2001 As of 09/30/17: 223,751 Miles - SOLD New owner report of 08/08/19: 234,408 Miles 2013 Mazda 3 HB - new in October 2012 As of 11/12/20: 78,895 Miles |
#24 |
2002 SL
K I just finished reading over the new or returning saturn owners checklist (which is AWESOME BTW). I'm wondering about the temp gauge (ECTS). My temp gauge always hovers around 1/4, and only reaches almost 1/2 when it's been running for awhile and it's very hot out. Is that normal?
#25 |
Ebay or dbelectrical.com seems to be the lowest cost starter replacement if you don't mind waiting.
Your '02 has the correct brass coolant sensor so the most likely culprit of a fluctuating temperature gauge needle is most likely a worn out thermostat. Replace it along with new coolant if its due.
VCX NANO |
#26 |
![]() ![]() ![]() Join Date: Oct 2012
2001 SL2
With ANY auto electrical problem...FIRST - Clean BOTH battery cables at the battery, and the battery terminals. ALWAYS !
It is cheap, easy, and quick. It will also surprise you much of the time ! JW |
#27 | ||
But I have to admit, when I saw you say this... Quote:
Insanity Test |
#28 | |
2002 SL
Anyhoo, I know I shouldn't have, dont' worry I didn't let them touch anything, but I went to VIP and had them run the diag test on the battery. They said my starter was going/gone. Then today my friend says, they can't test the starter without taking it out. Haven't been able to clean the cables yet as I don't have a lift, but I'm wheedling at my friend to get her to have her husband help me, possibly this weekend (I hope). Sunday friend coming to do tune-up. Tonight possibly serp belt replacement. VIP was like, it is all cracked, and I looked, and it was/is. Didn't drive the car at all on Sunday after having to jump it every time for Thurs/Fri/Sat. Then yesterday at noon, started up fine. Started up 4 times fine yesterday, and twice so far today. I keep vascillating back and forth between it's the starter, or it's a connection issue. I will do the cheapest/free things first. Then worry about a starter. Thanks again for all of your help on here. Don't kick me out for going to VIP, OK?! ![]() |
#29 | ||||||
![]() you may want to put a general location in your profile... might be someone nearby who can take a look, loan tools, etc. I pretty much have zero time these days, but willing to let you borrow my jack, stands, etc
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
#30 |
2002 SL
K this is what the EXP800 at VIP says about my battery/starter:
"Results Good Recharge Voltage: 12.55V Measured: 541 CCA Rated: 650 CCA Temperature: 95F Battery is Good but Low on Charge. Fully Charge Battery. Starter Test Results Cranking Skipped Voltage: 0.00V Time: 0ms Starter Profile Not Detected. Starter Test Skipped. Charging System Test Results No Problems No Load: 14.22V Loaded: 14.13V Ripple 57mV Charging System Output Test Normal" Did they actually test my starter??? |
#31 |
![]() Join Date: Jan 2012
1994 SW1
2000 SW2
Sounds like they " skipped " it.
Until you find someone who has basic knowledge of diagnostics and can then report the results back here this will continue to be a guessing game. Or if you have a few extra bucks you can buy a starter at www.dbelectrical.com for $ 50 and have someone install it. This will then eliminate one piece of the puzzle.
97 sl2 a/t 104 K 1989 GMC 3500 454 129 K, 1969 442 455 rat rod |
#32 | |
As mentioned by another member, power is the first consideration requiring everything before a starter to be in clean, good operating condition; battery, battery cables, their connections on both ends. Since your VIP report appears to show the power system is in good operating condition, the starter remains as the most likely problem. Starters can fail in as little as 70k miles or after 250k miles. Frequent short trip driving wears out a starter due to several starts in a day while long commutes to a job and back home with only two starts shows a starter lasting well beyond mileage when most cars are traded in, leaving someone else with the problem of long term wear and tear items that eventually wear out.
VCX NANO |
#33 |
2002 SL
You guys ROCK
Thank you ![]() |
#34 |
![]() Join Date: Jul 2015
I am having a similar problem with my 2002 sl2, but I have a new battery, a new alternator, and I replaced the starter about 5 months ago. The car is behaving as if the starter is bad, just a click from the starter when I try to turn it over, but I took it to the auto parts place, where I bought it, to have it tested and they have told me it is good. What do I do next?
#35 | |
#36 |
Read post #32. If you ensure the battery, battery cables, their connections are clean and in good condition, the starter is faulty. The battery can be tested at most auto stores but you have to examine cables and their connections carefully for severe corrosion, under the heavy insulation to be sure a previous battery didn't leak acid into cable lugs and eat away copper wires. If you are assured both battery cables and their connections (to engine and chassis ground too) and battery are good, replace the starter.
#37 |
Just a click and no other sound, no engine cranking or faint whir of an electric motor turning? As always, no-crank problems are best tracked down starting at the famous "purple wire"...
Also, I have found that part-store testing of starters is meaningless. Good ones can test "bad", bad ones can test "good"! |
Tags |
alternator, battery, starter, tune-up |
2004 Vue 5spd Won't Start | KJMcCoon | Vue Tech | 11 | 05-13-2014 09:34 AM |
header and intake 2002 vue 5spd? | dirtydawg | Vue Mods | 8 | 04-06-2014 02:55 PM |
1997 Saturn SL 5spd WONT START! | KeonTheGreat | S-Series General | 2 | 08-25-2013 06:46 PM |
02 SC2 5spd won't start cold/strange idle | flyjetguy | S-Series Tech | 4 | 12-29-2009 10:37 AM |
2002 SC2 won't start :-( | anderma8 | S-Series Tech | 7 | 02-18-2007 10:25 PM |
