![]() Join Date: May 2012
I have the Saturn SL2 1996 and I am trying to install an amplifier. Everything was going well until I attempted to connect the positive wire to the battery. Please help.
Use vice-grips to help remove the stock positive battery terminal bolt and replace it with something that looks/acts like this: http://www.autozone.com/autozone/acc...uestid=1009533
The proper way to fix a S-Series automatic is to replace it with a manual |
![]() ![]() ![]() Join Date: Apr 2009
Alternatively you can tap into the main positive bolt at the UHJB. it's free and easy.
DON'T FORGET TO ALSO USE A FUSE HOLDER IN LINE WITH THE NEW POWER LEAD.
97 SL2 DOB: 3/19/97 Date Obtained: 5/30/07 Status: Alive, 1/2 exhaust 2004 Merc G.Marquis GS DOB: 2/4/04 Date Obtained: 7/6/12 Status: Alive, no heat |
![]() Join Date: Jun 2011
I use something similar to what's in madpogue's link. Keep in mind the ring terminals that go around the posts have a wire gauge as well. You usually have to look around a bit to find the 8 or less gauge rings.
Tags |
amp, amplifier, battery, sl2, wire |
Where best to drill/route wire to battery? | brokendown | S-Series General | 4 | 12-19-2011 03:14 PM |
battery to fuse box wire. (thicknesses) | mattachuz | L-Series Tech | 5 | 11-17-2011 03:32 PM |
1.35v on the radio battery wire????????? | aaron7 | S-Series General | 9 | 07-19-2009 03:11 PM |
97 sl2 where to connect the remote starter wire for tach signal | claude thibault | S-Series Tech | 1 | 01-31-2009 01:39 PM |
Which wire to connect for an inline fuse? | turbobuick33 | S-Series Tech | 4 | 08-06-2007 11:34 AM |
