Old 05-01-2015, 11:54 PM   #1
mmarquez
mmarquez is on a distinguished road
1997 SC1
Default Cone filter dimensions
I'm trying to set up a cheap WAI. If I just want to clamp on the new filter on the stock hose what size does it have to be?
mmarquez is offline   Reply With Quote
Old 05-02-2015, 08:57 AM   #2
Default Re: Cone filter dimensions
Pretty sure you'll need a 6" length of 2.5" diameter PVC pipe to put the two together. Unless your hardware store is nicer than mine you'll have to buy the whole 10ft length of pipe, so you might as well get a 90 and 45 elbow and another clamp/connector, some PVC waterproof glue and replace all the intake piping. Should still be well under $30 total.
If you don't care for the look of white PVC you can get some steel wool and scuff it up, then paint it with spray paint.
Old 05-02-2015, 11:18 AM   #3
mmarquez
1997 SC1
So what size does the filter need to be?
Old 05-02-2015, 06:30 PM   #4
You may get it to stretch enough to fit around a 2.5" filter. The stock pipe isn't stiff enough to go on the inside of a filter.
Old 05-06-2015, 02:46 PM   #5
madeinUSA
madeinUSA is on a distinguished road
madeinUSA's Avatar
1992 SL2
1998 SW2
If you look for the K&N set-up (part #57-3012) for S series you will see what the "adapter" between the filter and the intake tube looks like.
A cheap alternative is a E-Bay WAI for anywhere between 35-45 dollars that comes with a cone filter...
http://www.ebay.com/itm/FOR-91-02-SA...9cce21&vxp=mtr
'92 SL2 / '91 SC / '06 Cobalt SS (supercharged!)....Proud American driving American made!
madeinUSA is offline   Reply With Quote
cold air intake
cone filter sandwich L-Series General 3 09-02-2011 11:55 PM
K&N Cone Filter Applefool Mods and Performance 6 05-05-2005 03:34 PM
KNN Cone filter steve69 Vue General 11 02-27-2004 10:41 AM
cone filter sp33doe Mods and Performance 10 02-24-2004 02:16 PM
K&N cone filter? jeffkics Vue General 17 12-15-2003 11:33 PM
