Old 02-13-2019, 11:19 PM   #1
A2Saturn
A2Saturn is on a distinguished road
A2Saturn's Avatar
1994 SL1
Default clutch master cylinder/slave cylinder recommended replacments help
I'm checking on RockAuto to replace my clutch master cylinder and slave cylinder. For choices, there are 12 brands of clutch master cylinders, and 13 brands of slave cylinders to pick from. The Exedy brand, is noted to as favorite among buyers.
They also have 7 master cylinder/slave cylinder assemblies, and the favored brand is Luk.
Any recommendations, or any brands to avoid altogether?
A2Saturn is offline   Reply With Quote
Old 02-13-2019, 11:29 PM   #2
Waiex191
Waiex191's Avatar
Default Re: clutch master cylinder/slave cylinder recommended replacments help
Here you go:
http://www.saturnfans.com/forums/sho...d.php?t=233551
Wagner CM140979 from rockauto, about $30. Has been working great for me.
Also note that this set does not show up in the Rock Auto Saturn list - but it fits and works perfectly. Hats off to flagtie who posted the FFR thread originally.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 02-14-2019, 01:37 AM   #3
RobertGary1
RobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to all
Luk is the brand you want. They provided the clutches for saturn oem. Always get the master and slave together. They’re not designed to be bled in service.
-Robert
Old 02-19-2019, 09:57 PM   #4
A2Saturn
A2Saturn's Avatar
1994 SL1
Placed an order for the Luk brand assembly. Also ordered Sil-Glyde, as I want to lube the rod prior to installation, so I don't hear squeaking when I depress the clutch.
Old 02-19-2019, 10:49 PM   #5
Waiex191
Waiex191's Avatar
Let us know how it works out. Interesting that the Luk set is the second cheapest, not counting the Wagner set that is not listed for the Saturn.
Bryan Cotton
Old 03-01-2019, 12:11 AM   #6
A2Saturn
A2Saturn's Avatar
1994 SL1
Had the Luk assembly installed today, and I'm pleased with the performance on it.
Prior to having it installed, I lubed the rod under the rubber boot with Sil Glyde. What a nice product that is.
Clutch Master and Slave Cylinder hddave43 S-Series Tech 8 07-13-2014 11:31 AM
Master/Slave Cylinder or Bad Clutch??? jstorm9000 S-Series Tech 13 01-10-2014 04:39 PM
CLutch master cylinder/slave cylinder azwesjr S-Series Tech 1 12-26-2013 10:26 AM
CLutch master cylinder/slave cylinder removal Tjflow S-Series General 7 02-17-2010 05:43 PM
Clutch Master/Slave Cylinder blackeagle1 S-Series Tech 5 10-22-2006 08:13 PM
