Old 09-05-2010, 11:58 PM   #1
zulaya
zulaya is on a distinguished road
2005 RELAY-3
2000 SL2
Default 00 SL2 Temperature Gauge
Hi!
Driving home tonight, I noticed my engine revving higher than normal. I started watching it and when it happened, my Temperature Gauge appeared to have died.
I started watching my temperature gauge and every time the gauge dropped to "zero" or "died" the engine would rev slightly higher for the same speed.
Turned on the cruise control and the same thing happened.
Any clue as to where to start with diagnosing/fixing this odd issue?
Thanks!
Mary
zulaya is offline   Reply With Quote
Old 09-06-2010, 12:21 AM   #2
Default Re: 00 SL2 Temperature Gauge
Replace the coolant sensor ASAP! It serves two purposes; to send the temperature data to the engine computer that adjusts for air/fuel mixtures while also sending the coolant temperature to the temperature gauge. The pcm (engine computer) needs it for everything. Yours is probably the old faulty plastic one. Brass is the replacement. Buy it from any auto store. Its a 5-minute replacement, next to the egr valve.
Old 09-06-2010, 12:41 AM   #3
zulaya
2005 RELAY-3
2000 SL2
coolant sensor == ECTS (Engine Coolant Temperature Sensor), right?
Thanks!
Mary
Old 09-06-2010, 01:01 AM   #4
quantumech
quantumech is on a distinguished road
Thanks!
Mary
Yes, that is correct.
Sasha: 2000 SL1, Manual, cracked head Sept. 2014. Donated Dec. 2014
I learn from my experiences. If I screw up, I'm sorry.
quantumech is offline   Reply With Quote
Old 09-06-2010, 01:31 AM   #5
Signmaster
Thanks!
Mary
That's the one, known to cause all sorts of issues on an S-Series Saturn!
Old 09-06-2010, 07:31 AM   #6
DonP
Check the first few sticky threads in the How-to Library forum for a lot more on the ECTS. When checking it, also check the connector for corrosion that may be preventing good contact. If you have to original resin tipped sensor, replace as a preventive measure, even if it looks OK now. It will fail eventually.
Low Temperature Gauge.... ClosetGeek S-Series General 20 04-29-2010 06:53 AM
Engine Temperature Gauge! tamigood45 2008 Vue 4 08-13-2007 03:19 PM
Engine Temperature Gauge PlutoZePlin Sky General 3 08-19-2006 07:50 AM
How does your temperature gauge act? jsevinsk Vue General 14 07-22-2005 04:48 PM
Temperature Gauge wat96sl1a Miscellaneous Tech 4 02-25-2000 10:13 AM
