Old 01-27-2003, 03:47 PM   #1
osx geek
osx geek is on a distinguished road
Question disabling door open chime
when i first bought my 97 sl2 about a year and a half it never made the door chime until one day my battery died (left the lights on) and when i charged it back up, everything had reset. since that day, i've had the damn annoying door chime come on.
it bugs because i like to have the door open when i'm cleaning the inside of my car listening to music, and the chime is a pain.
does anyone know of how to disable the door open chime? any help would be appreciated.
Juan
osx geek is offline
Old 01-27-2003, 05:08 PM   #2
Dach
Dach is a jewel in the roughDach is a jewel in the roughDach is a jewel in the rough
Default
There are several other things (like radio preset memory) tied in with the chime to discourage you from disconnecting it. If it bugs you that much you can disable it at the switch or find a way to permanently depress it. Welcome to the board, by the way.
Dach is offline
Old 01-27-2003, 10:07 PM   #3
wolfman
wolfman's Avatar
Default
When working on the car with the door open, engine off. Just remove and then reinsert the key...VIOLA! the chime will be off! Until the next time the car is started or the door open/closed.
wolfman is offline
Old 01-27-2003, 11:56 PM   #4
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
Default
But then he can't listen to music, Wolf.
I would pull the switch out, and jump the wires together, personally.
I have to ask.. the name.. are you a Mac user too?
~D.J.~
OhioVueBoy is offline
Old 01-28-2003, 01:44 AM   #5
osx geek
Default
~D.J.~
big time mac user. i've got two macs at work and a powerbook at home. all of them run os x. apple can't lose now - good looking os with a unix core. it's heaven...next to the ion of course
back to the thread though...i've considered taking out the switch, but, i'd prefer not to. i'd like to keep it as a last resort. what boggles me is why did it not chime before the battery died?
i once tried pulling the fuse labled door chime, but as dach mentioned, the radio stopped working. but that was with my stock radio. i haven't tried it again since, and now i have a pioneer deck. do you think it might do the same thing again?
btw - thanks for the welcome, dach.
osx geek is offline
Old 01-28-2003, 11:33 AM   #6
OhioVueBoy
OhioVueBoy's Avatar
2002 VUE 2.2L
Default
What makes me curious that I have noticed at work is .. if you leave the door open and chiming for so long.. the chime and dome light blink off for a second every minute or so. Wolf - do you know why this is?
~D.J.~
Old 01-28-2003, 03:25 PM   #7
pkuptrk
pkuptrk is on a distinguished road
Default chime disable
The chime is located on the back side of the fuse box under the radio.It is a or should be a blue box.I was having the same problem.I pulled mine out,opened it up and pulled out the metal bar that vibrates against a metal disk to make the chime noise.Then i replaced.If you dont replace it, your domelight when you open up your door will not work,nor will your dash lights.Hope this helps. Mike
pkuptrk is offline
Old 01-28-2003, 09:19 PM   #8
wolfman
wolfman's Avatar
Default
Ohio,
I "think" that's the "battery saver" trying to shut down the dome light, which it can't do with the door open and the key in the ignition.
wolfman is offline
Old 01-29-2003, 01:57 AM   #9
winc
winc is on a distinguished road
Default
The chime fuse is attached to the chime, dome light, stereo (i forget if it's the switched power line or both), and the rear defroster as far as I have discovered. So be ready to lose those too.
'95 SL1 auto (retired)
'02 RSX 5spd (her baby)
'05 WRX 5spd (my baby)
winc is offline
Door chime on when door open... billison Vue Tech 3 08-16-2008 07:39 PM
1997 Saturn SL1, Door open chime? RLSmith S-Series Tech 1 07-31-2007 11:22 AM
chime on when drivers side door open skenzer S-Series Tech 3 06-25-2007 01:20 PM
Door Chime Dings Whenever Door is Open Leadsled Coupe S-Series General 18 03-05-2007 03:30 AM
Door open chime??!! mr tibbs S-Series Tech 9 05-21-2006 08:55 AM
