Old 01-01-2003, 11:34 PM   #1
pkuptrk
pkuptrk is on a distinguished road
Dizzy oil consumption??
I have a 93 SL1.Somewheres it is using 1/2 quart of oil for 125 miles.I replaced pcv valve,02 sensor,enging coolant sensor,new plugs and wires,map sensor.It has 95000 miles and runs great.I don't notice anymore smoke than any other car produces on cold days.There is no leaks. can anyone help.
pkuptrk is offline
Old 01-02-2003, 02:35 AM   #2
SLeepr
SLeepr is on a distinguished road
SLeepr's Avatar
Default
Saturns are known for burning a little oil. However, you seem to be burning oil at a very rapid rate. To put your mind at ease, I would have your compression tested. At least rule out the really big things.
Saturns are notorious for having sticky rings. You can do the MMO piston soak (outlined on another post) to address this. Many times, this makes a major impact in heavy oil consumption. This may have to be repeated more than once.
If you have no luck, I would start looking in the direction of valve guide seals or <gulp> rings.
Good luck
SLeepr is offline
Old 01-02-2003, 09:33 PM   #3
BWhite
BWhite is on a distinguished road
Default compression ??
do a compression check see if # 4 Cyl is low , at 125 mi / qt you may have more than stuck rings . I thought I was bad at 350 mi /qt ...you win :-(
BWhite is offline
Stop your oil consumption with 20w-50 motor oil AtlanticBeach S-Series Tech 9 08-04-2009 11:38 AM
High Mileage Oil vs. Oil Consumption Thoughts? Maritime Storm S-Series Tech 26 08-13-2008 08:09 PM
Reduced oil consumption with synthetic oil rlacapra1 S-Series Tech 73 04-14-2007 01:09 PM
Major Oil Consumption, Car Shoots Oil Out the Tailpipe! SC2OilBurner S-Series Tech 11 08-02-2005 10:15 AM
Oil in coolant, white smoke, oil consumption Cheyanne S-Series Tech 13 04-28-2004 12:47 PM
