Old 06-22-2008, 01:03 AM   #1
Roundthirteen
Roundthirteen is on a distinguished road
Roundthirteen's Avatar
Default Exploded view 03 brakes
Does anyone have any exploded view pictures of the 03 rear drum brakes?
Roundthirteen is offline   Reply With Quote
Old 06-22-2008, 11:48 AM   #2
ImpalaSS
ImpalaSS is on a distinguished road
ImpalaSS's Avatar
Default Re: Exploded view 03 brakes
I looked at a few sites (www.saturnparts.com) that normally have good exploded views and could not find anything.............
94 Impala SS - Garage Queen - Under construction!!
94 Buick Roadmaster Wagon - Wife's Daily - Kids call it the "G-Pa" Mobile...........
06 Vue Black 4cyl. 5spd. - Daily Driver
ImpalaSS is offline   Reply With Quote
Old 06-23-2008, 07:43 AM   #3
fgwinn
fgwinn is on a distinguished road
Default Photos of 2004 rear brakes
Not exactly what you asked for but perhaps this will help. Here are two photos of the left side rear brakes on a 2004 AWD V6 Vue. These photos were taken at 53K miles. I disassembled the brakes to do an inspection and repair the bleeder valve on the wheel cylinder. I wanted to change the brake fluid and the left rear bleeder valve screw was frozen. I had to drill it out and replace it. A pair of bleeder valves from Saturn cost about $25. The rear brake cylinder from Saturn is priced at nearly $130. Aftermarket they run between $16 and $60 but no one seems to stock them.
Removing the rear drums was especially difficult. The problem seems to be that the drums wear at a faster rate than the shoes. So it is difficult to back off the adjusting screw enough to clear the ridge on the edge of the drum which has a thick coating of rust on it.
The maximum diameter of the inside of the drums is 251.5 mm. Mine are at 250 mm. I think they will last another 10K to 20K miles. The shoes I saw at the auto store with zero miles looked about the same as mine with 53K miles. Mine are a bit beat up from dragging the drums off of them, but, I think they will probably still work okay.
Only regret is that I did not unloosen the bleeder valve once a year or so to lessen the chance of freezing up.
fgwinn is offline   Reply With Quote
Radiator Exploded The Critic S-Series Tech 5 04-17-2009 05:19 PM
Need exploded view of TAAT parts? MichelleG S-Series Tech 0 04-07-2008 08:56 PM
Exploded engine Blammer S-Series Tech 4 10-28-2007 05:22 PM
Online exploded view of transaxle? gossimer68 S-Series Tech 0 10-03-2007 11:16 PM
Exploded diagram of spaceframe Newbeak S-Series Tech 14 12-20-2005 07:01 PM
