#1 |
![]() Join Date: Dec 2006
2003 VUE 3.0L
Just checking to see if anyone has the relevant manual for the 2003 3.0L V6 AWD Vue, and could post or send the information regarding removal of the steering wheel and horn pad/SIR down to the clock spring? (An exploded view would be great)
I have some of the information such as how to remove it, but was hoping there were pictures or diagrams I can reference if needed. Any help is much appreciated. |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2008
2005 VUE 3.5L
2007 VUE 3.5L
![]() Quote:
I visit forum monthly, if at all. Feel free to send private messages if you think I can help. Don't use visitor message as I never check those. |
#3 |
![]() Join Date: Dec 2012
Related question: do the two screws on the back of the steering wheel shroud need to be removed before the airbag can be disconnected? I can get the locks to disengage, but the airbag doesn't want to come loose. I feel like something's still attached.
#4 |
2003 VUE 3.0L
Take the top steering shaft cover off. (3 screws thru bottom) to expose the back of the steering wheel better. There are (4) plastic spring loaded catch posts that require that you insert a small flat blade screwdriver and twist, as you are pulling on that corner of the airbag/pad. Mine came off without any additional screws being removed. There are 2 wire connections to the back of the pad, but there is enough wire slack that the pad comes off fully before disconnection of those wires is needed.
Bookmarks |
Exploded view suspension pics? | budward | S-Series Tech | 2 | 05-03-2012 02:53 PM |
Exploded view 03 brakes | Roundthirteen | Vue Tech | 2 | 06-23-2008 07:43 AM |
Need exploded view of TAAT parts? | MichelleG | S-Series Tech | 0 | 04-07-2008 08:56 PM |
Online exploded view of transaxle? | gossimer68 | S-Series Tech | 0 | 10-03-2007 11:16 PM |
Exploded diagram of spaceframe | Newbeak | S-Series Tech | 14 | 12-20-2005 07:01 PM |
