Old 02-02-2022, 10:33 AM   #1
ascalv01
ascalv01 is on a distinguished road
Default 2002 SL1 1.9 SOHC makes a loud clank right before turning off
New here to the Saturn forum. Not new to cars and repairs. I was driving my 02 SL1 to work this morning and as soon I shut the car off, I heard a loud clank or clunk right before the engine stops turning over. I think I hear it during start up too but definitely not while the motor is actively running. It is the 1.9 SOHC engine 5 speed manual. The sound is coming from the passenger side of the car. Car has 214K miles. Occasional high idle sometimes 3K RPM sometimes then goes away (especially after turning the car off then starting it back up) and has some intermittent misfire depending on the weather. Would like some direction with that as well. Far too many times i've dumped money into parts only to find out it doesnt fix it. Throttle position sensor, Manifold absolute pressure sensor (car doesnt operate by way of MAF sensors as you all know).
ascalv01 is offline   Reply With Quote
Old 02-02-2022, 11:15 AM   #2
Waiex191
Waiex191's Avatar
Default Re: 2002 SL1 1.9 SOHC makes a loud clank right before turning off
There are 4 mounts for the engine and transmission. They wear out and tear. How are yours?
Also the exhaust hangers can fail due to rust.
Welcome to the forums.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 02-02-2022, 11:23 AM   #3
ascalv01
Mount are pretty much trash i would assume. car vibrates like hell but nothing too crazy at the moment. I have an upper one i havent had time to replace but was planning on it. Weather is about to get dumped on us here in the East and dont have the place right now to start tearing stuff apart. The mount was my initial go to so I got out of the car and tried moving the engine back and forth but could not get it move like ive had some cars in the past. (GM Dog bone motor mounts)
Old 02-02-2022, 12:27 PM   #4
cgg17
cgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nice
cgg17's Avatar
1995 SW2
I would say either motor mounts or belt tensioner.
I know the tensioners that are aftermarket will rattle and carry on as they bounce off of their "stop".
1994 Sl2 5spd: First Car, Stock: 56,576 (Totaled 1/10/2018)
1994 Sl1 5spd: Inherited, Stock: 494,500
1995 Sl2 5spd: Retired Daily, Not Stock: 196,000
1995 SW2 4spd: Daily, Stock: 104,000
Old 02-02-2022, 12:49 PM   #5
ascalv01
Thanks for the suggestion. I got a buddy at work who is going to help me start and stop the car so i can listen to it during lunch. Ill report back what i find. Hopefully its just a belt tensioner but it doesnt sound like a bearing growl
Old 02-02-2022, 01:06 PM   #6
SRGW
SRGW's Avatar
1997 SL1
Post Re: 2002 SL1 1.9 SOHC makes a loud clank right before turning off
Grab hold of the tailpipe and shake up and down if muffler hanger is broken pipe will hit rear axle and clunk.
1995 SL1 236,300 2005>2018
1997 SL1 95,025 2014>????
CHECK YOUR OIL!!
Old 02-02-2022, 02:32 PM   #7
ascalv01
I will also try that.
Update. Started the car at lunch 4 times. Didn't make the noise at all. Which makes me feel better, knowing it is probably not something internally. I'll keep troubleshooting and investigating. If I find out what it is, I will be sure to update. Please keep the suggestions coming, they are sure helpful. If you're in the path of the ice/snow storm. Stay warm and safe out there. On side note. It would appear the engine is dieseling both clockwise and counter clockwise but very briefly when shutting off. I know it can be somewhat normal but not ideal. If you know anything about that too, let me hear it.
Tags
clank, clunk, engine, noises, sohc 1.9l
It makes loud rattle sound when you first start it vikasevan S-Series Tech 5 12-20-2016 12:37 PM
Loud "Clank" When Taking out of Reverse. Pitcher S-Series Tech 5 07-12-2013 06:29 PM
Fan makes a loud rotating noise! gpifitted Ion Tech 26 01-13-2012 05:53 PM
steering wheel makes noise when turning prioris S-Series Tech 6 10-21-2011 06:01 PM
2000 SW2 Transmission Clank - loud SL2abuser S-Series Tech 5 12-22-2003 11:12 AM
