Old 04-20-2019, 02:22 PM   #1
TwoFistedJustic
TwoFistedJustic is a jewel in the roughTwoFistedJustic is a jewel in the roughTwoFistedJustic is a jewel in the rough
Default Steering Gear removal 02 SC2
The car is a 2002 SC2 with manual transmission and power steering.
I'm pulling out the steering gear in order to replace the tie rods all proper like according to the manual.
(Spent an hour trying to get a wrench around the rearward hose coupling, finally caved and bought a 18mm crowfoot and had it off in twenty seconds.)
Both outer tie rods, both gear to frame bolts, both hoses, and the pinch bolt to the linkage are now disconnected.
Except that steering gear won't disengage from the linkage. I'm a little afraid to damage something.
What is the trick to get the linkage separated from the gear?
TwoFistedJustic is offline   Reply With Quote
Old 04-20-2019, 03:37 PM   #2
TwoFistedJustic
Default Re: Steering Gear removal 02 SC2
Got it without breaking anything.
It required a special tool called a "double box end wrench" which was placed with one end on the transmission, and the other on the frame. Then lay a flat screwdriver across the wrench and gently pry up on the linkage. A drop of liquid wrench also helped.
power steering, sc2, steering gear, tie rods
Steering Gear Bolt Spavlat S-Series Tech 2 09-09-2013 09:29 AM
Steering Gear HELP!!! BarnOwl S-Series Tech 13 03-23-2008 12:13 PM
Gear shift removal jacobs_ladder74 S-Series General 32 04-05-2006 06:30 PM
gear sift knob removal dtcoastguard Vue General 15 01-06-2005 03:23 AM
Manual gear shift knob removal Semantics Fox Mods and Performance 12 08-14-2001 09:36 AM
