Old 03-14-2010, 09:48 PM   #1
josemite
josemite is on a distinguished road
2002 L-Series 3.0L Sedan
2002 SL1
Default Oil in coolant bottle
I have a 02 L300 with oil in the coolant bottle. It is also overflowing.
josemite is offline   Reply With Quote
Old 03-14-2010, 09:51 PM   #2
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Default Re: Oil in coolant bottle
Cracked head gasket?
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
unkle bik is offline   Reply With Quote
Old 03-15-2010, 07:08 AM   #3
Wolfc70
Wolfc70 will become famous soon enoughWolfc70 will become famous soon enough
Nope, failed oil cooler. Should be much cheaper than head gaskets. Though flushing the block and radiator can be a PITA.
"I tip my hat to the man who drives an Alfa Romeo" - Henry Ford
Wolfc70 is offline   Reply With Quote
Old 03-15-2010, 08:22 AM   #4
midway
midway is a jewel in the roughmidway is a jewel in the roughmidway is a jewel in the rough
2000 L-Series 3.0L Sedan
Failed oil cooler would be where I would go, the oil cooler is mounted in the valley under the intake system.
midway is offline   Reply With Quote
Old 03-15-2010, 09:52 AM   #5
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
You're probably right.
I didn't see that it was a V6 until you brought that to my attention.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Oil in Coolant Bottle josemite S-Series Tech 4 03-14-2010 05:24 PM
2003 ION Coolant Reservoir Bottle R&R siamesecat Ion Tech 0 08-05-2007 12:42 PM
Mysterious Coolant Leak Near Resevoir Bottle Fricken eh! Miscellaneous Tech 7 09-04-2004 09:08 PM
Upper hose on coolant bottle belleaudb S-Series Tech 6 06-17-2004 10:21 PM
What's in my coolant bottle? amazinghl Miscellaneous Tech 2 08-16-2002 09:44 PM
