Old 08-31-2006, 08:54 PM   #1
Sheldon
Sheldon is on a distinguished road
Sheldon's Avatar
Default 97 to 95 interchange????
Quick Question: I've got a 97 saturn sl2 that needs a motor and i've got a good motor from a 95 sc2. There both automatics and i was wondering if i could drop in the motor from my 95 into my 97???
Sheldon
Sheldon is offline   Reply With Quote
Old 08-31-2006, 08:58 PM   #2
eljefino
eljefino's Avatar
1995 SW1
Default Re: 97 to 95 interchange????
should go pretty easy, I would keep the same year injectors and ignition module as what computer you're using. You can abandon the 2nd coolant temp sender in place and plug your remaining plug into the lower/further back sensor.
http://www.turbosaturns.net/forum/viewtopic.php?t=2211 <- lots o good info
Old 08-31-2006, 09:11 PM   #3
Sheldon
Sheldon's Avatar
cool. but, which motor has 2 temp sensors??? I'm actually doing this for a buddy of mine.
Sheldon
Old 08-31-2006, 09:57 PM   #4
eljefino
eljefino's Avatar
1995 SW1
the early one has two sensors, but the later car only requires one. The remaining upper one looks the same, threads the same, but isn't the same inside, and is intended for the gauge. A computer output runs the gauge in 97.
Old 09-01-2006, 12:25 PM   #5
Ken Benson
Ken Benson is on a distinguished road
1997 SC1
I want to second the recommendation of keeping the '97 injectors when you swap the engines. '95 and '97 injectors LOOK the same, but are in fact different(low impedence vs. high impendence), and while the car would start with the wrong injectors, it would not run correctly. Also, keep the '97 throttle body, as there are minor differences there too. The intake manifold is the same, so no need to replace it, just swap the TB and the fuel rail, and all will be fine.
You'll also want to keep the engine sensors (EGR, knock sensor, etc.) from the '97. They are all easy to swap out, and you'll find that some of the '95 sensors wouldn't connect to your wiring harness anyway, due to different fittings.
Lastly, if you are pulling the engine from the top, remove the TB from the engine before you pull it. The IAC and TPS sensors are on the back end of the TB, and have a real tendency to get damaged by the top lip of the firewall when the engine is pulled. It'll save you a bit of hassle, and it's just two bolts.
Good luck!
Ken Benson is offline   Reply With Quote
A/C Compressor Interchange CowboyDren S-Series Tech 1 05-14-2009 05:59 AM
2.2 interchange sl2clone L-Series Tech 4 03-02-2007 10:44 PM
transmission interchange paqrat S-Series Tech 0 06-27-2006 01:50 AM
Interchange Help? ilfyrfytr S-Series Tech 1 10-24-2005 01:05 PM
F/P interchange mazdakicks88 S-Series Tech 1 09-26-2005 09:44 PM
