Old 06-07-2021, 04:55 AM   #1
RacingRN
RacingRN is on a distinguished road
Default MP3 Trans Issue
ok guys, new member here. Long time lurker. Have a 98 sw dirt race car. Took lick a few months ago and bent up the front end. Broke all motor and trans mounts. Got it all straight and replaced the entire front end. When i drained the tranny the fluid was pink like it had water in it. Replaced with fluid and went to race. Normally i start the race in second and shift to 3rd and run the race in 3rd. This time When i let out on the clutch in 1st it was bogging down and i was having to keep my RPMs up. i ran the race in second and was having to pump the clutch in the corners to keep momentum. Checked codes, compression, coil packs and other stuff. We are at a loss. Any suggestions appreciated.
RacingRN is offline   Reply With Quote
Old 06-09-2021, 09:56 PM   #2
toggenburg
toggenburg's Avatar
Default Re: MP3 Trans Issue
Offhand, what fluid had you been using, and what did you put into that manual transmission?
Old 06-10-2021, 03:35 AM   #3
RacingRN
Dex 3 compatible fluid. Whatever the cheapest was at O'Reilly's
Old 06-10-2021, 09:39 AM   #4
bumpdraft
bumpdraft's Avatar
1998 SW2
In reading the initial post, you are forced to run the entire race one (1) gear LOWER. This is not a subtle change.
For the casual driver, this would be the equivalent of going to the shopping mall and driving the parking lot with the parking brake firmly engaged.
Old 06-10-2021, 03:33 PM   #5
RacingRN
That is correct. I have been working. but going to check shifter cable today.
Old 06-11-2021, 12:50 AM   #6
Signmaster
It sounds to me like something other than the tranny. Anything in the tranny that would create that much drag would be clanking, smoking, rattling, etc.
If you can turn the front wheels when it's on stands then it's not something tweaked that bad in the driveline.
If it's bogging letting out the clutch, it has to be way down on power. I'd look into fuel first myself.
Old 06-11-2021, 09:42 AM   #7
RacingRN
We figured it out. Evidently when we hit the wall the clip that holds the shift cable on the trans came off. We fabricated one and it is working well now.
Old 06-14-2021, 12:03 AM   #8
Signmaster
Was it stuck in 3rd gear still?
Either way, sounds like it ended up being a cheap fix.
Old 06-14-2021, 07:30 AM   #9
RacingRN
no . From what i can tell i was starting in 4 and shifting to 5th..or something like that.
Old 06-16-2021, 12:26 AM   #10
Signmaster
Well in that case, it looks like the clutch is in good shape. No wonder it was bogging!
Trans issue wastedpotential Ion General 0 06-15-2019 12:23 PM
98 SL2 Trans Issue ghal79 S-Series Tech 3 02-10-2016 07:50 PM
Trans issue Mkrown Introductions & Greetings 0 03-23-2013 01:22 AM
2rd trans same issue moms-car S-Series Tech 10 10-04-2012 08:09 PM
trans issue please help!!! rattlebox S-Series Tech 0 09-28-2012 01:53 PM
