Old 12-24-2021, 04:25 PM   #1
Aspenglade
Aspenglade is on a distinguished road
Default Moog Strut Problem
2001 Saturn SL1 ATM, base model
I installed MOOG ST8511 strut assembly for the front. Although, specs state it's compatible, the struts arrived with the strut mount configuration reversed.
The strut mount holes on the SL1 are designed in the triangle configuration with the two holes on top and the one hole at the bottom (facing outward).
I used the widow makers to compress the new strut springs and rotate the strut mounts 180 degrees. No issues in the installation.
Also, found there are no cam bolts. They are factory.
Wil there be any issues by fixing the error?
Aspenglade is offline   Reply With Quote
Old 12-24-2021, 05:06 PM   #2
Default Re: Moog Strut Problem
Either I'm misunderstanding something, or you put far too much effort into simply spinning the strut mount around. The fronts spin on a bearing between the car body and the upper spring perch.
Camber bolts aren't required if you grind out both layers of the knuckle mount area to give the upper bolt the full oval to slide in.
Old 12-24-2021, 05:21 PM   #3
Aspenglade
1. Strut mounts: I tried just spinning the mounts by hand 180 degrees. It would not move. I had to compress the springs.
2. Camber bolts: Ah, ok, I understand now.
Old 12-24-2021, 05:24 PM   #4
Waiex191
Waiex191's Avatar
They need to move for steering.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 12-24-2021, 05:49 PM   #5
Aspenglade
Hmm, I see that they would need to turn for steering, but wouldn't they rotate with the weight of the car anyway, when the springs are compressed? So, it wouldn't be an issue. Right?
Old 12-24-2021, 06:07 PM   #6
The front spring perch has to turn on a bearing so the wheel can turn and change the car's direction. You may not have had enough leverage with just your hands to spin a brand new setup but you could have installed the mount end then use anything to help spin the bottom around would have worked just as well.
The only time you have to worry about the mount->spring orientation on the fronts is when the strut doesn't come out in the middle of the mount/spring like it does on the S-Series (like older Subaru's that use a spring perch spacer dohicky that shoves the top of the strut to one side of the spring rather than through the middle).
Old 12-24-2021, 06:30 PM   #7
Aspenglade
Ok, I only installed the right front, I have the left front to install. I'll try that. Thank you.
Old 12-29-2021, 11:59 PM   #8
PrestonIII
PrestonIII is a jewel in the roughPrestonIII is a jewel in the roughPrestonIII is a jewel in the rough
Is there a left strut and a right strut? And did you possibly install them on the wrong side?
I've never put struts on an S series, so I'm just venturing a theory.
On another note, not specifically strut related, but I know a guy who reversed sides on a set of front calipers once. They bolted up and hoses mounted up. But he couldn't bleed the brakes out. Why? Because the bleeder screws were then on the bottom, and the air was at the top! lol, I know what you're thinking but it wasn't me! It was a new tech at a mechanics shop I worked at many years ago.
Preston
PrestonIII is offline   Reply With Quote
Old 01-02-2022, 03:04 AM   #9
TomM96
TomM96 has a spectacular aura aboutTomM96 has a spectacular aura about
I bought a used '95 pickup; i checked the rear drum brakes.
One side had two shoes intended for the forward side, the other side
had both shoes for the after side....
Old 01-05-2022, 09:26 PM   #10
Highmile
Highmile's Avatar
The top of the top mount turns, it has to or the spring would wind up every time you turned the wheels. However it may be tight enough you can't turn it by hand. Clamp the strut in a vice and put a long screw driver thru 2 of the studs on the top and turn it.
Highmile
'95 SL1 744k and counting
MOOG replacment springs, yet another MOOG fail Tobacconist Vue Tech 15 11-14-2020 10:54 PM
Strut Replacement with MOOG Cargo Coils Daishi360 S-Series Tech 33 11-12-2018 08:48 PM
moog strut mount and kyb gr-2 shocks possible? 2000 Ls2 3.0 Onlineguru L-Series General 1 03-12-2014 03:22 AM
Dealer replaced strut, strut mount, and strut bearing tomcatt1 Vue General 17 10-03-2007 04:53 PM
Strut Bar Problem OU812 S-Series General 2 10-11-2006 03:08 PM
