#1 |
![]() Join Date: May 2008
I have a 2000 SL1, 119,000 miles on it that has had a small coolanet leak on it for about 6 months. I've had to add coolant to the tank about every 6-8 weeks since it started.
Last fall, I went and replaced the thermostat with a hotter 195 degree one. Before it got too cold I replaced the gasket in the thermostat again thinking that it might have been the source of the small leak. I just checked all of the bolts again and they were fine. Over the weekend the coolant light came on, again, and while I was driving on the highway I watched the temp on my scanguage climb from the 190s to 225 before I found a place to stop. What coolant remained in the tank was foaming a little and I refilled the coolant. Later that day the coolant light came on again. Before I go and drop $200 on a new radiator and hoses, does anyone have any other ideas what could cause a small leak to turn into a gusher? Is this a no brainer radiator crack or could it still be something less costly? Thanks in advance. |
#2 |
Water pump. Check it. Dont let the car get into the RED on the gauge or you will be looking for a new Head instead of just a water pump.
Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto 2010 SCCA Mohud Street Championship-2nd Place |
#3 |
Water pumps have a typical life span of around 80 K miles, so your is about due, and as noted above, it the #1 suspect location, once you have verified that all clamps are holding and hoses are OK.
Is is perhaps a bit early for the radiator leak. It typically happens in the 10-12 year window. Best way to inspect the pump is to pull the passanger side wheel and splash shield to get a good look. If it has a visible leak, replace it ASAP. Once the start to go, they can go very fast. (Mine went from no visible leak under the car to gushing perhaps a reservoir full per mile in a matter of 6 miles.) |
#4 |
If it's boiling over replace the radiator cap with a new one. It's $5 at most parts stores.
Is the leak visible at all? Drivers side is usually radiator, passenger side is either the water pump weeping/leaking or the coolant reservoir boiling over due to a bad cap not holding pressure.
2007 Ion 2 Quad Coupe 5-speed manual 183K miles *gone* 2007 Chevy Equinox LT 205K miles 2018 Chrysler Pacifica Touring L 74K miles |
Bookmarks |
Small radiator leak | WellsWebDesign | S-Series Tech | 5 | 11-20-2009 10:45 PM |
Small oil leak | duganator | S-Series Tech | 16 | 09-13-2007 11:18 PM |
Small oil leak, help please | blacktruckryder | S-Series General | 8 | 09-09-2006 12:18 PM |
Small antifreeze Leak | SmoothSoundsxtr | S-Series Tech | 4 | 10-27-2003 12:47 AM |
Small water leak-- from what?? | mantis | Miscellaneous Tech | 5 | 08-30-2002 08:53 AM |
