Old 12-27-2021, 09:02 PM   #1
mattwithcats
mattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the rough
Default Maxi Fuses…
All,
Maxi fuses are becoming harder and harder to find.
I suggest you keep a spare or two in the glove box…
50 amp
https://www.rockauto.com/en/parts/bu...AX50,fuse,2676
30 amp
Pennzoil Maximum Power 0W-30, Champion COS3600...
NGK BKR6E-11 spark plugs
Old 12-28-2021, 12:21 AM   #2
Default Re: Maxi Fuses…
People buy those? What a waste of money, though it is hard to argue with $0.90 for one.
Almost every parts car I had I stripped it for the fuse's along with other easy to reuse/repurpose parts before scrapping. All the Fords and GM's I've worked on use them as well so I assume they're still "littering" junkyards across the country. Trucks in general, 3/4t's specifically, tend to have the higher rated fuses and more of them.
Old 12-28-2021, 03:53 PM   #3
onlinebiker
onlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to all
I have a pretty fair collection of em - just in the parts cars out behind the barn...
Currently owned
93 SC2 M(anual)
96 SC2 M
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 12-28-2021, 04:18 PM   #4
PrestonIII
PrestonIII is a jewel in the roughPrestonIII is a jewel in the roughPrestonIII is a jewel in the rough
1994 SL2
Darn!
Just one more thing I forgot to pick up when I was at the wrecking yard last week.
Odd thing is, I just had to replace the 10 Amp fuse that powers my Hazard Flashers and Bright Lights Indicator. And I had to dig around for a fuse for it! Luckily there was a spare in the underhood fuse block. I have no idea what blew that fuse or when it actually blew (within the last 3-4 days).
Preston
PrestonIII is offline   Reply With Quote
Old 12-28-2021, 04:46 PM   #5
dummo
dummo's Avatar
1997 SW2
Do our S-Series Saturns use that 50MAX fuse? According to RockAuto.com they are not listed when I search for parts that fit my 97 wagon.
I was going to purchase 4 fuses but it was going to cost $6.99 to ship them.
• 1994 SL1 new traded
Old 12-28-2021, 06:13 PM   #6
mattwithcats
Note sure the first and second gen cars used the 50...
Another kit to get is the Busmann Easy ID kit,
has seven each of 5, 10, 15, 20, 25, and 30 amp light up fuses..
https://www.eaton.com/us/en-us/skuPage.ATC-ID-SK.html
https://www.rockauto.com/en/parts/bu...IDSK,fuse,2676
Note that there are spare ATC fuses in the fusebox, but not Maxi's
Old 12-29-2021, 08:11 PM   #7
TomM96
TomM96 has a spectacular aura aboutTomM96 has a spectacular aura about
On my 1965 (air-cooled) VW -- 6-volt system -- I found it saved time
if I removed All the fuses (only ~10) once a year, and carefully cleaned those connections ... and also the light sockets at the rear.
My 1982 VW rabbit never blew a fuse.
I don't recall any of my Chevy pickups blowing a fuse.
My '97SW Saturn only blew one fuse ... after a very close range
lightning bolt, which disabled the ignition via the security system, the following day.
I am very impressed with the reliability of the Saturn electric system,
with possible exception of the gen-2 IgSw.
Fuses... mattwithcats S-Series Mods 0 01-26-2019 09:13 PM
97 Sl2 keeps blowing ign 3 30a Maxi fuse jaredthefail S-Series General 1 03-28-2015 08:10 PM
Where are the Fuses??? grambo Outlook General 9 02-27-2007 09:42 AM
fuses msbplane Ion Mods 5 09-26-2006 08:24 PM
Fuses ? Crypto1969 L-Series General 2 03-06-2006 11:35 PM
