Old 08-30-2009, 02:53 PM   #1
quantumech
quantumech is on a distinguished road
Default greasing outer tie rod ends
I just realized that the new ones need to be packed. I've never packed anything with grease before, so I'm unsure of how much I should cram in there. Do I just go until it start to ooze out of the dust cover/boot?
Sasha: 2000 SL1, Manual, cracked head Sept. 2014. Donated Dec. 2014
I learn from my experiences. If I screw up, I'm sorry.
quantumech is offline   Reply With Quote
Old 08-30-2009, 04:20 PM   #2
Default Re: greasing outer tie rod ends
You pump in good EP-2 grease until the boot JUST starts to swell. If you get in too much just pinch the boot and wipe up the excess. A little squeezeout will not hurt anything.
Old 08-30-2009, 06:00 PM   #3
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1993 SL2
And a nice swivel head on your grease gun will help. I have Mobil 1 loaded in my gun, and have a 90 degree head on the end of a flexible hose. Gets me into some of the tighter spots.
And for the more A/R among us - pop a zerk fitting cap on it and it'll be perfectly clean the next time you grease it (it keeps dirt from collecting on the outside and being forced inside when you add new grease).
MiSaturn is offline   Reply With Quote
Old 08-30-2009, 07:17 PM   #4
A rag works as well and does not fall off.
On a side note. I have found that the Amsoil grease does not separate as bad as the Mobil-1. Have used both of them for quite a while.
Old 08-31-2009, 01:02 AM   #5
SLCraig
Using Redline CV2 here... No complaints. RL is always a good product!
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Outer Tie Rod Ends Grrrrrrr.... Growser S-Series Tech 1 10-19-2008 01:22 PM
Replacing Outer Tie Rod Ends FirstSL2 S-Series Tech 1 10-10-2007 03:26 PM
Outer Tie Rod Ends Replaced David 93 SL2m S-Series Tech 6 04-09-2007 09:43 PM
Replacing Outer Tie Rod Ends eljefino How-To Library 2 11-07-2003 09:14 PM
Tie-rod ends... bennett9000 S-Series Tech 7 09-03-2003 07:51 PM
