Old 09-06-2021, 05:04 PM   #1
Keblar
Keblar is a jewel in the roughKeblar is a jewel in the roughKeblar is a jewel in the rough
Default Worried engine seized, but hopefully just the Starter
Skip to the break if you don't want the details.
I stopped to gas up on the way home from my hour plus commute. When I tried to restart I got instrument panel, radio, and AC but no starter, just a click.
Immediate thought was that it was an odd battery issue/bad ground, so I checked leads. Wife was only a mile away so i got her to come to try a jump. While waiting I tried a few more times, and noticed temp was just a little over 1/2, and the fan was engaging with ignition off. I checked oil and coolant - coolant was fine, but oil was lower than expected having just changed oil and topped off perfectly 10 days earlier.
Wife arrived, and we hooked up the cables - no change. I let it sit and had her hold RPM's above idle. I tried a few more times, but then saw smoke coming from the engine, as she jumped out to say the same thing. Smoke seemed to be coming from the starter area, and had a distinct electrical smell. We gave up, got the recovery straps from home and towed it the last mile.
After reading old posts of smoking starters after running with little or know oil, I was worried the engine had seized, even though oil wasn't extremely low and temp was never in the red. (engine oil light never came on either). I was able to pull plugs, and got some lube in the cylinders, and it turned over by hand though. Also, after settling, oil was still lower than expected but only right at the lower hash.
At this point I'm going to assume a seized starter. I never pegged it, knowing it can burn out if held for too long - only held 3 to 4 sec at a time - but i guess repeated tries with solenoid engaged but starter not turning were too much. I don't see any burned/melted wires, but I also can't get a good look at the cable from solenoid to motor.
Going with another DB electric since this one has lasted 8+ years and about 55k miles in salt conditions, even though it regularly got hosed with hot coolant for half its life before I properly fixed the intake manifold coolant leak.
2002 SL2 335k + Miles
Keblar is offline   Reply With Quote
Old 09-07-2021, 08:28 AM   #2
Highmile
Highmile's Avatar
Default Re: Worried engine seized, but hopefully just the Starter
I'd put a wrench on the crank pulley and give it a turn before I spent any $$ at all.
Highmile
'95 SL1 738k and counting
Old 09-07-2021, 11:36 AM   #3
bumpdraft
bumpdraft's Avatar
1998 SW2
Take comfort in the fact that no one has ever seized a stock S-Series. Usually, the cause is over-revving and eating an exploding valve. Either that, or reaming the cylinder out to the point of losing too much compression for combustion...
Old 09-07-2021, 11:49 AM   #4
Keblar
Highmile
Oh I did. Turning easy using a Standard 3/8 wrench with plugs out. Confirmed that pistons are moving in opposition and topping out properly.
Old 09-07-2021, 11:59 AM   #5
Keblar
A seized engine wasn't my 1st thought, but any other time I've had a starter fail the symptoms were different. I think the solenoid has always failed 1st, and so far that doesn't seem to be the case given the relay click and the electrical smoke.
I have had a loaner car -82ish Buick Regal V6 IIRC- seize from a bad oil pump. Dash light came on and I called the owner, "Hey, oil level is good, but the idiot light is on. It's probably the oil pump." "No, I don't think so. It'll be fine, just drive it on back." Stopped for gas and it wouldn't start again. That experience had me worried.
Old 09-07-2021, 02:09 PM   #6
When and if you're interested in fault diagnosis, perhaps disassembling the starter may reveal why it clicked but didn't run. A click means the starter solenoid powered up, throwing out the starter gear to engage the engine flywheel while closing a large set of heavy duty electrical contacts to apply battery power to the starter motor. Clicking without the starter motor running usually means the contacts burned out, the brushes are worn down and make very little contact to the commutator or the armature windings burned out.
Old 09-08-2021, 08:15 AM   #7
Ricketts
Ricketts is a glorious beacon of lightRicketts is a glorious beacon of lightRicketts is a glorious beacon of lightRicketts is a glorious beacon of lightRicketts is a glorious beacon of light
2000 SC1
I'm thinking it's just the starter. Cheap fix, but tight space to work in. Hopefully fixes the issue
2000 SC1 - Bone Stock
No power windows, no power locks, no AC, no cruise control...just a good DD that has nothing to break on it
Ricketts is offline   Reply With Quote
Old 09-08-2021, 08:36 AM   #8
onlinebiker
It is the starter.
Anyone takes a bet against it - they're a moron.
If you are going to do the job yourself - it would be awesome if you can get it up on a lift. It makes it far less grueling. Also - if you have never done the job before - removing the passengers side wheel and fender liner make it easier to see what you are doing.
The hard part for the first timer is the starter bolt closest to the block. You can' t see it with the starter in the way. It' s done by feel.
And - if you think you will be keeping the car long term - swap that bolt with a stud - so you don' t have to line it up blind. Just slip the starter in place , install the bolt to the rear you can see - then put a washer and nut on the stud...
Currently owned
93 SC2 M(anual)
96 SC2 M
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 09-08-2021, 09:07 AM   #9
Waiex191
Waiex191's Avatar
I also vote starter. The top hidden bolt isn't bad. Use a socket with an extension. Remove the hidden bolt first, replace it last so the other bolt holds the starter.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 09-08-2021, 03:28 PM   #10
Keblar
I've replaced the starter before, but it was THIS one which means it was over 8 years ago. I have no particular memory of it being difficult or not, but it doesn't stick in my mind as being a repair that i hate to tackle. Other than access it seems pretty "plug and play".
The splash guard is already off from rotating the engine, so I'll have that.
Also, Hell Yeah, a lift would be awesome, but I'd settle for a garage (it's on the "to do" list) or even just a paved driveway first. 😆
Old 09-08-2021, 05:01 PM   #11
Cardboard boxes in any size to lie on if a creeper isn't used.
Old 09-08-2021, 06:31 PM   #12
onlinebiker
I feel your pain....
Once upon a time - I was 19 years old and had to pull a starter from a donor 67 Lincoln Conntinental donor car - then the starter on my 67 Connie - then install the donor.
In the driveway.
No ramps.
In the winter.
In Anchorage Alaska.
A whole day of misery...
Currently owned
93 SC2 M(anual)
96 SC2 M
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 09-10-2021, 10:32 AM   #13
Keblar
No ramps.
In the winter.
I hear ya. I started using an old runner rug, on top of an yoga mat on top of cardboard this past winter when I had to cut off the rust frozen bolt for the lower control arm. At least I had the snowdrift to use as a seat back when I needed to lean back and rest.
Old 09-16-2021, 03:50 PM   #14
Keblar
Follow up: It was indeed the starter. Replaced the dead one with a DB Electric and everything is back to "normal".
For whoever comes across this while digging for starter replacement help, it is indeed a deceptively annoying job. It's only 2 nuts and 2 bolts, but the bolts are long for the amount of turning space you have. One of the bolts is unknowable. It's a blind fumbling effort, both on and off. A cheap plastic mirror helps to eyeball what you're actually doing (a la the Richpin video), but only helps. It's a weird depth so even finding an extension that gets deep enough but is still able to fit in the cramped space is an exercise in frustration. If you have an air or cordless ratchet I think that would speed things up as well. Don't be like me and think, "Oh, this is simple, I don't need to drag out the compressor," only to get in the thick of it and say, "Oh. Yeah. I remember this PITA now," and wind up suffering through forearm cramps unnecessarily. A magnetic socket would probably be helpful too.
Old 09-16-2021, 04:18 PM   #15
Waiex191
Waiex191's Avatar
I screw the bolts in and out by hand, and just torque/break torque with the ratchet. On the top one, by hand means with a socket and extension but no ratchet.
Bryan Cotton
Old 09-19-2021, 04:55 PM   #16
You don't swap the bolts for a stud and nut? Odd. Same thread/size as the intake manifold; then you just hang it on the studs.
Old 09-19-2021, 05:22 PM   #17
Waiex191
Waiex191's Avatar
Not sure if that was for me or not, but no I haven't. For some reason this job seems a lot easier to me than it sounds on the forum.
Bryan Cotton
Old 09-19-2021, 09:16 PM   #18
billr
Yeah, same here. Getting that top screw in is a trivial task for me. I don't have ay extra engines or manifold studs laying around, and going to JY for them would be silly, since there is little-or-no benefit.
We all have our different areas of expertise/skill. I, for instance, can not change a serp belt in five minutes... Does my skill with the starter balance out my slow serp belt changes, and raise me out of the "inept" category???
Old 09-25-2021, 11:55 PM   #19
macbox
macbox will become famous soon enough
macbox's Avatar
This is the solution: So much easier to hang the starter on studs than to mate bolts to the engine/transmission.
#4, "Betty" 1995 SC2m, 167K, rebuilt engine, Garage Queen. Still squeaks and rattles but goes like hell.
macbox is offline   Reply With Quote
Old 10-10-2021, 10:39 AM   #20
TomM96
TomM96 has a spectacular aura aboutTomM96 has a spectacular aura about
I know acquaintances with one or more aftermarket joints in their
bodies (knee, shoulder, hip).
The other day, working underhood, i noticed that several tasks
encountered would be more pleasant if my wrist, or elbow
(or both) had 190 degrees of flexion, rather than the stock
90 degrees +/_.
Perhaps we should contact the ever-willing healthcare industry
about re-designing some of the replacements ....
@ BillR :
The other day i had opportunity to manipulate the serpentine belt
into the engine compartment, onto the pulleys, etc.
I found that it:
(a) wanted to jump off pulleys onto which carefully placed,
(b) when prevented from jumping off the pulleys, it tends to
jostle just so that one edge will rest on outside of the 'guide'
on the side of the pulley. By this means, it steals the slack
needed to route over the other pulleys. Sly trick!
TomM96 is online now   Reply With Quote
Tags
seized, smoke, starter
seized engine rv93 S-Series Tech 26 10-10-2013 12:09 AM
Seized engine saturn hippie S-Series Tech 15 07-27-2011 12:27 AM
engine seized?? fml. chefeagles Ion Tech 32 12-01-2010 02:01 AM
Significant change in SL2 engine humming noise - should I be worried? rreuben S-Series General 4 02-22-2006 02:01 PM
