Old 08-23-2018, 09:23 PM   #1
Magicman
Magicman has a spectacular aura aboutMagicman has a spectacular aura aboutMagicman has a spectacular aura about
Default Brake line flare - Bubble / Double?
As stated in a different post, I'm replacing a portion of a right rear brake line. I rented a double flaring tool kit ....but I see that Saturns use bubble flares? Can I use this kit and make it work, or should I buy a bubble flare kit? Brakes are too important to not get it right!
Thanks,
Mike
Magicman is offline   Reply With Quote
Old 08-23-2018, 09:31 PM   #2
Waiex191
Waiex191's Avatar
Default Re: Brake line flare - Bubble / Double?
If you are splicing two lines a double flare with a flare union is fine.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 08-23-2018, 11:57 PM   #3
Bubble flares can be accurately 'faked' with doing a half-double flare. Get the first half of the double done, then just don't fully crimp it down (don't crimp the 2nd part down much at all).
My '00 Silverado 2500's hydroboost assist couldn't tell the difference, weak vacuum boost on a lightweight 4cyl won't have a snowball's chance in a hot place of noticing. Went over the scales pulling 13k lbs that way too, no problems with leaks or stopping (100% truck brakes, no trailer brakes).
Either way, if you're splicing one line into another it doesn't matter what the car use's...just what the fittings/line you bought use.
Double Bubble toil and engine trouble? Border Walker S-Series Tech 4 08-16-2013 01:27 PM
Brake Double Check eltech S-Series Tech 4 08-08-2012 01:38 PM
Dang brake line bubble flares junker S-Series Tech 4 11-22-2009 02:43 PM
SC2 frt. brake hose change. Flare wrench Size? Abe95SC2 S-Series Tech 0 04-24-2004 11:48 PM
Saturn plans to double vehicle line in three years Laurence General Saturn Discussion 14 10-30-2003 02:15 AM
