#1 |
Ok, I had a craked head, got it fixed, flushed the system several times and discovered it was still leaking oil. Got it fixed, and today I reflushed the system, which had oil in it. After driving for 5 mins. theres oil in the tank again. So, is there just a lot of oil in the radiator? I bought a new coolant tank so that was clean, and got new radiator hoses too....Should I just flush again? Im realllly tired of having to do this, and Im on my 3 gallon of coolant.
Just wondering whats up.
Im not crazy, just bored... http://www.cardomain.com/id/the_skin_eater ---Chek it out. All my time goes to the Talon...My girlfriend is jealous. But my car is jealous that I sleep with her... |
#2 |
![]() Join Date: Feb 2005
1996 SL1
Did you get all new hoses? I replaced 6...and there's still the small one that connects to the coolant tank that I have to replace. My mechanic flushed my radiator & heater core for an hour to get all the junk out. And even still, there was a (very very small) amount of oil showing up in my tank...but only enough to "run a ring around" the top of the coolant.
96 SL1 202k 98 Windstar 123k |
#3 |
Guest
Posts: n/a
Try not to laugh too hard, it works.
Re-fill with clean water and some dishwasher detergent. Run the car until it's warm and then let it cool and drain. Repeat the process until the drained water/detergent is clear. Finally, replace the thermostat and re-fill with coolant/water mix. It does a great job of eliminating oily sludge in the cooling system. |
#4 |
I was wondering what I could use to help with the oil....I'll try it...
And no, I didnt replace the lil ones. I mainly wanna get rid of the bulk of the oil, a small amount would be satisfactory right now. thanx.
#5 |
That's automatic dishwasher detergent you want to use..................
#6 |
1996
Only.
I had experiences with these Saturn cracking heads and the only thing that works is dishwashing liquid. 1) You got to take out the thermostat. 2) Put in 2 oz dish liquid and fill up with water. 3) Drive for 5 minutes until warm. 4) Dump the water and then flush with a garden hose by purring the water into the pressure container and letting out by the radiator upper hose (detach that) and engine outlet. Run the water until clear. Repeat 5 times. Put the thermostat back. Fill with antifreeze. |
#7 |
Since the thermostat is in its special housing...can the actual thermostat come out?
#8 |
When you say pressure tank, you mean the coolant resevoir?
And, after taking out the thermostat the detergent and water just goes into the coolant tank right. I will try to do all this tomarrow, let ya know how it works... Oh yea, any ol detergent will work?
Bookmarks |
head gasket replacement | wishihadacamaro | S-Series General | 10 | 07-23-2009 02:49 PM |
Head Replacement. | Crasoum | S-Series General | 7 | 08-02-2008 03:50 PM |
head replacement was a success | Oh3dakota | S-Series Tech | 9 | 02-05-2008 04:07 PM |
Head unit replacement... | saturnd00d | Ion General | 10 | 08-28-2004 11:30 AM |
95 SL Head Replacement | roger | Miscellaneous Tech | 7 | 02-25-2001 03:16 AM |
