Old 12-29-2021, 01:41 PM   #1
Lightfoot2002
Lightfoot2002 has a spectacular aura aboutLightfoot2002 has a spectacular aura about
Default 2002 SC2 power port
Hello All:
A few years back I smelled an electrical burning smell in the passenger compartment of my 2002 SC2. I checked underneath the dash and found that a wire from the power port(cigarette) lighter was burned. A previous owner had installed a wire from this port to the junction block. I removed the wire. Now I feel I need this electrical port as insurance to plug in a tire pump in case of a flat tire or to recharge a cell phone.
Can anyone tell me how exactly to supply power to this port? What guage wire, where to connect into the junction block etc. Was there a special original wire harness I can get to solve this? Thanks to all.
Lightfoot2002 is offline   Reply With Quote
Old 12-29-2021, 03:49 PM   #2
trottida
trottida's Avatar
Default Re: 2002 SC2 power port
It's recommended to run a fused wire from the UHJB positive post through the firewall and tap a switched circuit to use a relay harness.
Look at post 8 of this thread to see how it is all mapped out .....
Seat heater install with pictures....
1999 SL2 MT (299,400 km @ 11/2021)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 12-29-2021, 07:44 PM   #3
TomM96
TomM96 has a spectacular aura aboutTomM96 has a spectacular aura about
Just in confirmation....
I ran a laptop PC off the cigar lighter in my '97SW for quite a while.
As OldNuc pointed out, the OEM arrangement is only designed for
a short burst of power. I removed & tightened the 'connector' at least
once, and concluded that if I were to use the lighter as a power point,
that a fused connection to the UHJB (via firewall grommet) would be
necessary.
I later bought for $8-ish a power point accessory that had a superior
connection... but i never used it, in favor of wifi router at my apartment.
2002 Vue Power-Take-Off x2006nzl Vue Tech 2 09-19-2013 08:10 PM
Is the high side A/C service port a one way port? MadPuppy S-Series Tech 8 06-14-2012 06:02 PM
No power to computer port tom1scott Vue Tech 3 01-30-2011 05:21 PM
2002 Vue 3.0L Loss of Power Routs Vue Tech 0 10-27-2007 12:33 AM
Cig Lighter / Power Port Blowing the Fuse boomer359 S-Series Tech 6 03-07-2007 12:59 AM
