Old 12-09-2021, 05:14 PM   #1
Coehawk
Coehawk is a jewel in the roughCoehawk is a jewel in the roughCoehawk is a jewel in the rough
Coehawk's Avatar
1999 SW2
Default SES light blinking
Hello, I have a 1999 SW2 with about 240,000 miles on it. I recently had the EGR valve replaced and it was running just fine. This morning when I started it the car was running really roughly, and stalled as I backed out. Started it up again just to get it in the garage.
Went to work, came back to take it to the same mechanic, and same thing. This time I noticed the SES light came on and was blinking. Now, I'm having it towed to the mechanic. Had a strong smell of gas as well, and my wife said some white exhaust had come out (she was going to follow me).
Anything specific I should be prepared for?
Thanks!
Coehawk is offline   Reply With Quote
Old 12-09-2021, 08:13 PM   #2
Kaervak
Kaervak has a spectacular aura aboutKaervak has a spectacular aura about
Kaervak's Avatar
Default Re: SES light blinking
When the SES light flashes that's a catalyst damaging misfire. Since you smelled a strong raw fuel smell and it was running rough, I'm going to assume one or more cylinders lost spark and raw fuel was being dumped through the exhaust. Could be as simple as a failed spark plug or could be that the ICM failed. Either way, fairly easy repair and not too horrifically expensive. Another possible cause, while quite rare, is a failed PCM. I'm one of a very few people that have had a PCM go bad and it was not cheap to fix. I highly doubt that's the case though. Either way, let us know what it was when you hear from your mechanic.
Kaervak is offline   Reply With Quote
Old 12-09-2021, 09:54 PM   #3
Coehawk
Coehawk's Avatar
1999 SW2
Thank you for the heads up. I will definitely give an update.
Old 12-10-2021, 12:58 AM   #4
Kaervak
Kaervak's Avatar
After a bit more thinking, it could also be a stuck open fuel injector. Just pouring fuel into the cylinder. That's a pretty easy fix too thankfully.
Old 12-13-2021, 01:46 PM   #5
Coehawk
Coehawk's Avatar
1999 SW2
Solved!
It was a malfunctioning ICM. While he was at it he replaced the plugs and ignition coils, and cleaned out the fuel injectors.
So far, so good.
Thanks for the technical information!
Old 12-14-2021, 03:08 PM   #6
Coehawk
Coehawk's Avatar
1999 SW2
Well, maybe not completely solved. Starts fine, but seems to idle too fast at stop, and has a bit of hesitation accelerating. Seems to run okay at highway speed, but a little Ďlurchí as it goes into the higher gear.
Old 12-14-2021, 10:58 PM   #7
trottida
trottida's Avatar
What does your temp gauge read when the car is up to operating temperature?
1999 SL2 MT (299,400 km @ 11/2021)
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 12-17-2021, 04:08 PM   #8
Coehawk
Coehawk's Avatar
1999 SW2
Temp seems fine; normal for itís history. Mechanic didnít pull any new codes and said itís running fine for him. No acceleration issues, no increased idling.
Weird!
Old 12-17-2021, 04:22 PM   #9
trottida
trottida's Avatar
Weird!
This picture shows where it should be in a GEN2 like yours. Is that your "seems fine" range? Have you owned the car since new?
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 12-17-2021, 10:19 PM   #10
PrestonIII
PrestonIII is a jewel in the roughPrestonIII is a jewel in the roughPrestonIII is a jewel in the rough
With an ECM replacement, the car may just need to relearn it's programming.
First thing I would do is NOTHING. Just drive it till you get a hundred or so miles on it in combined city and highway miles. Then see if the problem persists.
If it persists, THEN check other things. especially that ECT (engine coolant temperature) sensor. If the computer doesn't see the engine warm up, it will keep the idle a little higher than normal.
Preston
PrestonIII is offline   Reply With Quote
Old 12-18-2021, 03:10 PM   #11
Coehawk
Coehawk's Avatar
1999 SW2
Thanks!! Iíll do that and report back to the forum.
Old 12-19-2021, 01:33 AM   #12
onlinebiker
onlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to allonlinebiker is a name known to all
Preston
This. Exactly.
Currently owned
93 SC2 M(anual)
96 SC2 M
98 SL2 A(uto)
99 SC2 A
01 SC2 A
01 SC2 M
02 SC2 M
02 SL2 A
02 SL2 M
parts
2 94 SC2 parted out
2 96 SC2
98 SL2
Old 12-19-2021, 01:36 AM   #13
Greg1
Greg1's Avatar
1997 SW2
I believe it was the ignition control module that was replaced not the PCM so there shouldn't be any relearn.
97 SW2 5-Sp 372k
Old 12-19-2021, 01:14 PM   #14
billr
I was tempted to post the same opinion; but then considered that a bad ICM was causing misfires that probably gave abnormal O2 sensor readings. The PCM may have been chasing this bogus O2 data with fuel trims that need to be corrected once the misfiring is gone. So, some LTFT "relearn" may be necessary, but I doubt this will take more than a few minutes/miles of driving once the engine is hot.
Old 12-20-2021, 01:30 PM   #15
Coehawk
Coehawk's Avatar
1999 SW2
Yes, I'm the original owner, and yes, the temp is right about at the picture.
I drove it about 30 miles this morning (~25 highway, 5 city) and it had one 'hiccup'. I had to slow down on the interstate (from 60-35) and then speed back up, and that's when there was a slight lurch or hesitation. Seemed to run fine after that, though.
SES light came on a few minutes later down the road (solid, not binking), so I'm not sure why that happened unless it just took a bit for the computer to realize.
I probably should get a code reader.
Old 12-20-2021, 04:17 PM   #16
Coehawk
Coehawk's Avatar
1999 SW2
Okay, got it scanned at Advance Auto and it came back P0122 throttle/pedal position sensor a circuit low input.
Looking up the symptoms, this seems to fit as much as anything.
We'll see if this repair does the trick.
Old 12-23-2021, 09:12 PM   #17
TomM96
TomM96 has a spectacular aura aboutTomM96 has a spectacular aura about
Does your '99 have the plastic intake manifold back adjacent the firewall,
and a small (coffee-can style) pre-cat on bottom of the exhaust manifold?
OldNuc suggested that a used-junkyard ThrottlePositionSensor might be
better than new ones (unless OEM, which best).
I bought a couple new aftermarket TPS in 2019. I judged the Standard
Motor Products and NGK looked OK ... but I have not yet replaced them on my 2000SW2 with Cali emissions.
Advice from a mechanic: Be careful using throttle body cleaner, to
Not contaminate the position sensor with the solvent.
Old 12-24-2021, 01:26 AM   #18
Waiex191
Waiex191's Avatar
Originally Posted by TomM96 View Post
Does your '99 have the plastic intake manifold back adjacent the firewall, and a small (coffee-can style) pre-cat on bottom of the exhaust manifold?
Just for reference my '99 has the aluminum intake and the pre-cat. I think the plastic intake manifold was a 2000+ thing.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 12-27-2021, 05:45 PM   #19
TomM96
Thanks for the photo of the Al manifold !
I made great haste to view it soon -- in case it would mate up on
my 2000, in which case I'd retire my plastic.
So the '99 has Gen-2 induction, but Gen-3 exhaust ... must have
been some staff meetings to agree to that !
SES light blinking tmaugham S-Series General 3 01-03-2011 11:32 PM
blinking SES light countrygirlcna S-Series Tech 15 04-07-2010 08:41 PM
Blinking SES light... mdurisseau S-Series Tech 13 03-17-2010 07:43 PM
Blinking SES light saturncrzy S-Series Tech 4 03-19-2009 11:54 AM
Blinking Passlock light when off ribbon Vue Tech 2 11-03-2008 09:15 PM
