#1 |
![]() Join Date: Aug 2015
My Saturn seems like it is stuck in 3rd gear. I had autozone check it out and they gave me the codes p0700 and p0747. The Saturn seemed to run fine when I would shift from park to "I" or "L" gear but from going to park to "D" it would drive as if it were starting out in a higher gear meaning that it drives really slow until 30mph and the. It would be fine. I had a mechanic inspect the car after I got the codes and he said it needed a new trans. I got a new trans and it is still doing the same thing. The car is still giving the same codes as well. How can I fix this? Thanks!
#2 |
Is the trans a VTI OR AF23 5 SPEED ?
Is the Ion a coupe or 4dr ? What are the real codes (P0747 is not listed) |
#3 |
This is what I could find. I agree we need to know which transmission you're dealing with.
DTC Code: P0700 Description: Transmission Control System (Malfunction Indicator Lamp Request) Probable Causes: Sensor or solenoid faulty Update control unit software - Check for the latest control unit update Powertrain or Engine Control Module faulty Transmission system malfunction __________________________________________ DTC Code: P0747 Description: Pressure Control Solenoid A Stuck On Probable Causes: Sensor or solenoid faulty Connector terminal contact is damaged or corroded Wire harness - Check harness for correct voltage, open, short to ground or short to voltage Update control unit software - Check for the latest control unit update Powertrain or Engine Control Module faulty
2007 Ion 2 Quad Coupe 5-speed manual 183K miles *gone* 2007 Chevy Equinox LT 205K miles 2018 Chrysler Pacifica Touring L 74K miles Last edited by ruley73; 08-05-2015 at 12:54 AM. |
Bookmarks |
2003 ion m43 trans p0705 p0700 code | qwertio12 | Ion General | 3 | 04-11-2015 03:18 PM |
2003 VUE OBD II codes P0223 P0700 etc,etc | WBrown | Vue Tech | 2 | 01-17-2015 02:39 PM |
2002 saturn dtc code p0700 and p1779 | sat1971 | Vue General | 2 | 05-27-2012 10:13 PM |
2006 Saturn Ion - P0700 | Nick Adam | Ion Tech | 2 | 01-30-2012 10:54 AM |
2003 L300 error codes P0700 & P0727 | kssbss | L-Series General | 1 | 12-28-2008 08:29 PM |
