Old 08-02-2009, 12:01 PM   #1
DankAllumni
DankAllumni is on a distinguished road
1995 SL
Dizzy Rough Idle Wont Stay Running
I have 95 Sl 1.9 SOHC 145K 5 Spd I replaced the head gasket and intake manifold gasket, while I had the Intake off I cleaned the TB. I reassembled the motor filled the fluids. Primed the fuel system its starts but runs very rough and dies about 3-5 seconds later any ideas?
DankAllumni is offline   Reply With Quote
Old 08-02-2009, 12:44 PM   #2
Default Re: Rough Idle Wont Stay Running
Replaced the original engine coolant temperature sensor (ECTS) yet? If not, use the Forum Jump below to find the How-to library about it. The original faulty one fails and tends to run the engine rich all the time.
Old 08-02-2009, 02:21 PM   #3
DankAllumni
1995 SL
No, I havent but I will I broke it when replacing the gasket didnt think much of frankensteined it back together and put it back in. Any idea of cost?
Thank You All In Advance Any Help Is Greatly Appreciated.
Old 08-02-2009, 10:20 PM   #4
rc1488
rc1488's Avatar
Ten bucks. Replace it.
Its Vital to the cars performance
Old 08-06-2009, 03:35 PM   #5
DankAllumni
1995 SL
I replaced the sensor and same trouble only now it starts but takes throttle to keep it running starts very sluggish but once reved past 2k it smoothes out. While it is running the coolant light is on but no Check Engine.
Old 08-06-2009, 05:19 PM   #6
The coolant light is from the float inside the coolant reservoir sticking or broken; remove the container for a thorough sloshing of HOT water and detergent to remove built up scum that may be causing the float to stick.
Were the plugs and wires ever replaced? Ignition module and coils removed and cleaned of corrosion including the mounting bolts? The ignition system is grounded so a clean corrosion free ignition module/coils ensures less misfiring from the ignition system.
When the ects was replaced did you check the two-wire connector for corrosion? This corrosion has the same effect as never replacing the older plastic ects - rich running all the time.
Old 08-06-2009, 05:21 PM   #7
DankAllumni
1995 SL
Update I replaced The Connector Body and my problem magically went away added a gal of 93 and its all good. Thanks Everyone For The Help
Old 08-06-2009, 10:11 PM   #8
quantumech
quantumech is on a distinguished road
Connector body?
Sasha: 2000 SL1, Manual, cracked head Sept. 2014. Donated Dec. 2014
I learn from my experiences. If I screw up, I'm sorry.
quantumech is offline   Reply With Quote
Old 08-06-2009, 10:49 PM   #9
Slammin96
Slammin96 is on a distinguished road
Originally Posted by quantumech View Post
Connector body?
Lol I was thinking the same thing.
My first Saturn: 1996 SC2 5-speed
Kill List:
2006 Mitsubishi Eclipse 5-speed
2003 Mazda 3 5-speed w/ CAI & Exhaust
Slammin96 is offline   Reply With Quote
Old 08-07-2009, 08:27 AM   #10
rc1488
rc1488's Avatar
Connector body?
The ECTS connector
my car wont stay running and idky scrapmedallord S-Series Tech 1 02-16-2009 11:54 AM
sl2 wont stay running, driving me nuts spare_change S-Series Tech 9 11-03-2008 09:30 AM
Idle running rough! G-knee S-Series Tech 1 03-18-2008 03:10 PM
High Idle and rough running quasar S-Series General 5 12-14-2007 03:48 AM
car wont stay running pkuptrk Miscellaneous Tech 1 01-04-2003 11:06 PM
