![]() Join Date: Jul 2009
1995 SL
I have 95 Sl 1.9 SOHC 145K 5 Spd I replaced the head gasket and intake manifold gasket, while I had the Intake off I cleaned the TB. I reassembled the motor filled the fluids. Primed the fuel system its starts but runs very rough and dies about 3-5 seconds later any ideas?
Replaced the original engine coolant temperature sensor (ECTS) yet? If not, use the Forum Jump below to find the How-to library about it. The original faulty one fails and tends to run the engine rich all the time.
VCX NANO |
1995 SL
No, I havent but I will I broke it when replacing the gasket didnt think much of frankensteined it back together and put it back in. Any idea of cost?
Thank You All In Advance Any Help Is Greatly Appreciated. |
#4 | |
Its Vital to the cars performance
Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto 2010 SCCA Mohud Street Championship-2nd Place |
#5 |
1995 SL
I replaced the sensor
The coolant light is from the float inside the coolant reservoir sticking or broken; remove the container for a thorough sloshing of HOT water and detergent to remove built up scum that may be causing the float to stick.
Were the plugs and wires ever replaced? Ignition module and coils removed and cleaned of corrosion including the mounting bolts? The ignition system is grounded so a clean corrosion free ignition module/coils ensures less misfiring from the ignition system. When the ects was replaced did you check the two-wire connector for corrosion? This corrosion has the same effect as never replacing the older plastic ects - rich running all the time.
VCX NANO |
#7 |
1995 SL
Update I replaced The Connector Body and my problem magically went away added a gal of 93 and its all good. Thanks Everyone For The Help
#8 |
![]() Join Date: May 2009
2000 SL1
Connector body?
Sasha: 2000 SL1, Manual, cracked head Sept. 2014. Donated Dec. 2014 I learn from my experiences. If I screw up, I'm sorry. |
#9 |
![]() Join Date: Aug 2009
1996 SC2
My first Saturn: 1996 SC2 5-speed Kill List: 2006 Mitsubishi Eclipse 5-speed 2003 Mazda 3 5-speed w/ CAI & Exhaust |
#10 |
my car wont stay running and idky | scrapmedallord | S-Series Tech | 1 | 02-16-2009 11:54 AM |
sl2 wont stay running, driving me nuts | spare_change | S-Series Tech | 9 | 11-03-2008 09:30 AM |
Idle running rough! | G-knee | S-Series Tech | 1 | 03-18-2008 03:10 PM |
High Idle and rough running | quasar | S-Series General | 5 | 12-14-2007 03:48 AM |
car wont stay running | pkuptrk | Miscellaneous Tech | 1 | 01-04-2003 11:06 PM |
