Old 03-29-2009, 03:06 PM   #1
Ortega flyer
Ortega flyer is on a distinguished road
Default 2007 ION loss of power steering?
Hi, I have a 2007 ION that has been a great car. It just hit the 45000 mile mark and now the power steering fails almost every other day. I have to stop the car shut off the ignition and start it up again then it goes for a day or so and fails? The dealer tells me it will be $1000.00 without even looking under the hood? Is this a regular problem with the ION? What's Up?:
Ortega flyer is offline   Reply With Quote
Old 03-29-2009, 04:10 PM   #2
Default Re: 2007 ION loss of power steering?
Electric Power Steering..............and all the inherent problems it may have. You have what most naysayers against old school power steering with hydraulic pumps, hoses, leaks, etc., complain about as EPS is rearing its ugly head as electric power steering matures and specific issues appear to become sore points similar to hydraulic ps problems. Two different ways to lessen steering forces, two different problems with power steering. One is oil related, the other electric.
If you have a warranty, get thee to the dealer asap.
VCX NANO
Old 04-05-2009, 10:29 PM   #3
DukeCitySC2
DukeCitySC2 is on a distinguished road
DukeCitySC2's Avatar
2006 ION-2 Sedan
1993 SC2
I have a 2006 Ion, took it in for a few minor things just before the warranty lapsed. When I picked it up, they told me they "had" to replace the PS. I hadn't noticed any problems. The mechanic told me he routinely moves the wheel back and forth on test drives to listen for a noise. He said he heard it, and that it indicates the gears in the PS unit are worn out. He also mentioned the $1,000 price tag....
DukeCitySC2 is offline   Reply With Quote
Old 04-06-2009, 01:43 AM   #4
2006 ion2
2007 ION-2 Sedan
if it was under warranty, it would not have cost you $1000
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 04-07-2009, 08:12 PM   #5
DukeCitySC2
2006 ION-2 Sedan
1993 SC2
It didn't, I said he mentioned the $1000 price tag
Old 04-07-2009, 08:21 PM   #6
2006 ion2
2007 ION-2 Sedan
sorry, misunderstood
2007 Saturn Ion 2
Old 05-23-2009, 11:45 AM   #7
lpereyra
lpereyra is on a distinguished road
2006 ION-2 Sedan
My '06 Ion just did this yesterday! I've been looking online to see if any other Saturn owner has had the same problem. I have 57,000+ miles on it and this is the first time it's happened. Any resolution to your problem?
lpereyra is offline   Reply With Quote
Old 05-23-2009, 01:31 PM   #8
IMkenNY
IMkenNY is on a distinguished road
I had a bad voltage regulator (in the alternator) that caused an intermittent power steering failure on my 07 Redline Ion. Make sure your electrical sytem is holding a steady ~13.8 volts.
I would also check the condition of the underhood inline power steering fuse connections.
IMkenNY is offline   Reply With Quote
Old 05-23-2009, 06:24 PM   #9
Way2QWK
Way2QWK is on a distinguished road
Most likely needs the steering column with motor replaced. they tend to overheat and shut down. If it has a code c0475 then Thats your problem. hope you have extended warrenty
***Saturn Tech and owner of Planet Automotive in Tucson AZ. Specializing in Saturn repairs.
94 SW2- custom intake and ported throttle body
2003 Saturn Vue 3.0 v6
Way2QWK is offline   Reply With Quote
Battery light, loss of power steering and pegged temp gauge all at the same time SLM crew chief S-Series Tech 13 09-18-2009 10:28 AM
06 ION loss of power and shifts hard 06SATURNION Ion Tech 6 03-19-2009 03:30 PM
Loss of power steering aaronstubbe Vue General 3 08-29-2008 01:15 PM
Temporary loss of power steering ratgirl Ion Tech 2 02-19-2008 02:20 AM
Power Steering fluid Loss on L300 Rogue L-Series Tech 4 01-23-2007 11:07 AM
