#1 |
![]() Join Date: Dec 2006
1994 SC1
what whould cause my automatic seatbelts not work on my 94 sc1 the pass sid works fine and does it help if i say that it will go down cause i gave it a little push and it went up like 1 inch then i closed the dorr iand it went down but still no belt so any ideas?
#2 |
![]() Join Date: Jan 2007
1994 SC1
English please?
If your Saturn isnt running right, try some of these! -MMO Piston Soak -ECTS R&R -Check/Change Oil And You'll Be Good For Another 50,000 Miles! =p |
#3 |
![]() ![]() Join Date: Jul 2005
Periods are your friend.
"When you stop to fill up on oil, don't forget to check the gas" 98 SL2 MT 213K+ Daily Driver 38+ mpg 97 SL2 AT 150K Original Owner 95 SL2 MT 220K+ My Saturns have BRASS ones! |
#4 | |
![]() Join Date: Sep 2006
1994 SL1
![]() Quote:
What would cause my automatic seat belts not to work on my 1994 sc1? The passenger side works fine. Does it help if i say that it will go down if i give it a little push, i closed the door, and only went up one inch. The Drivers side belt will not return to the closed door position, any ideals? That is what i got out of it...
Current: 1998 SL2 Auto issues 112K 1995 Eagle Vision 3.5L TSI 117K Past: 98 SL1 254k miles Valves Burnt. 94 SL2 125K miles Diff Pin Blew! 94 SL1 Sold @134K. |
#5 |
Lubricate the seat belt track system. Start with WD-40 and then go to a light spray grease. THe WD-40 will help lube and loosen things up as well as cleaning up the tracks. If the belt has stuck in a middle position you may be to late to revive it.
A lousy day in paradise is still a day in paradise. |
#6 |
Its a 13 year old electrical/machanical part that doesnt last forever.
If both sides didnt work, I'd say a fuse or controller module. Since only one side isnt working, the seatlect mechanism on that side is bad. Sometimes lubing it helps, but somehow I doubt any type of maintenence have ever been done to the tracks, so its way too late for that. Either replace it or convert the seatbelts over to the 1995 style and never worry about it again.
Mike -1991 Turbo SL2. 11.809 @ 116.488 mph www.differentracing.com -2001 Limited Edition SC2 (#78) -2001 Chevrolet Suburban -2007 Saturn Aura XR -2011 Rally Yellow Chevrolet Camaro 2SS RS |
Bookmarks |
auto seat belt problems | 94IAcoupe | S-Series Tech | 3 | 02-10-2009 03:18 PM |
Auto Seat Belt. | 1994Saturn | S-Series Tech | 2 | 10-16-2008 01:59 PM |
Auto seat belt module... | johnnypraze | S-Series General | 4 | 09-27-2004 11:47 PM |
Auto Seat Belt problem | myoung | Miscellaneous Tech | 3 | 05-23-2003 10:21 AM |
Seat belt prob in 91 SL2... | Dach | S-Series Tech | 1 | 01-24-2002 09:28 PM |
