Old 09-08-2004, 10:35 AM   #1
MBman
MBman is on a distinguished road
Default Seat Belt Question for 2000 SL2 Owners
This one has me baffled. I pulled out my passengers side seat belt today and noticed that the belt was damp and wet. We have had a lot of rain (due to Francis) but I cannot figure out where or how this area got wet, the carpets are dry.
Perhaps I am not looking in the right place for possible entry points? Any help would be appreciated
Thanks
Ron
MBman is offline
Old 09-08-2004, 03:00 PM   #2
DJMaverick
DJMaverick is on a distinguished road
DJMaverick's Avatar
Default
Do you have a sunroof? I know on my 97 SL2 the molding around the sunroof leaks a little when there is very heavy rain.
DJMaverick is offline
Old 09-08-2004, 03:09 PM   #3
M.Nguyen
M.Nguyen is on a distinguished road
M.Nguyen's Avatar
1993 SL2
Default
remove the door sill...i think your answer will lie right about there...
M.Nguyen is offline
Old 09-08-2004, 03:44 PM   #4
MBman
Default
no sunroof, so what part of the doorseal top or bottom ?
MBman is offline
Old 09-08-2004, 03:51 PM   #5
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default
If you have a sunroof, make sure the drain tube is clean and connected. The one on my brothers 2001 SC2 was disconnected where it attaches to the sunroof.
At first they tried to say it was leaking from where we ran a powercable for an amp through a rubber grommet neat the master cylinder. Some how water could run down the firewall, below the drivers seat, over a hump in the floorboard and pool up under the rear seat without getting the firewall or carpet wet under the front seat. Hummmmm. So we took it home, sprayed water directly where they said it ws leaking. Nothing. No leaks. Let the water rain down onthe car and it started dripping down the "B" pillar and pooling up in the rear of the car. I took the car back to the dealer for him, explaind it was still leaking. They said it was because of the cable running through the firewall. They then called in the tech who previously worked on the car and the guy in charge. I let them explain how they knew for a fact that is were it was leaking from.
Then I took out the pictures showing where it was really leaking from. They were all speechless. We all then walked into the repair bay, he took off a couple trim panels, and what do you know, the drain hose had come off the neck on the sunroof.
It was something we obviously could of fixed. But we figured, why should we. They basically called us liars, se we had to proved them wrong, plus the car was still under warrenty. Still the look on their faces after I pulled out the pics was priceless. I wish I had the camera to take pictures of that..
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Low Saturn is offline
Old 09-17-2004, 09:14 AM   #6
MBman
Default
I am still struggling with this problem, Ivan has decended and the belt is wet again. I cannot see anywhere water can get in or I am just missing it. What has to be removed to visualize the area where the belt rolls up
MBman is offline
A question for all 2000+ SL owners xoBabyStarxo143 S-Series Tech 3 12-01-2004 07:08 PM
attn: Saturn owners! Custom seat belt pads! group order! BlueIonDriver General Saturn Discussion 0 03-15-2004 03:11 PM
All Vue Owners Must Read My Daughter Got Traped Back Seat Belt vue4u2nv Vue General 10 09-30-2003 09:40 AM
power seat belt question(s)? SLM crew chief Miscellaneous Tech 12 05-03-2003 04:19 PM
The seat belt question ym42 S-Series Tech 11 01-26-2003 11:40 AM
