Old 03-21-2013, 03:08 PM   #1
Firestarter
Firestarter is on a distinguished road
2002 L-Series 3.0L Wagon
Default No fuel 2002 Saturn LW300
I am having a no fuel issue with my saturn and have tried just about everything influding checking the fuel rail and everything in this thread
http://www.saturnfans.com/forums/sho...=starter+fluid
I am wondering where the ground connection is on the car? I am also wondering if it's ok to use starting fluid in the car?
Firestarter is offline   Reply With Quote
Old 03-21-2013, 03:26 PM   #2
Default Re: No fuel 2002 Saturn LW300
1-Did you try the suggestions I made in the link? What are the results?
2-Starting fluid sprayed into the intake is safe for testing. Go ahead and post results.
3-Before hunting for fuel pump ground, did you try the suggestions for testing fuel and pressure in the link?
Old 03-21-2013, 06:36 PM   #3
Firestarter
Tested for fule pressure at the fuel rail and at the filter nothing there. No fuel at all.
Old 03-22-2013, 10:17 AM   #4
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Pretty good indication the fuel pump is dead then. Do you hear the pump run for a few seconds when you turn the key?
Dead fuel pumps are a fairly common issue with L's, or with all cars that have internal tank pumps for that matter.
Jerry N
Groucho Marx
Old 03-22-2013, 11:15 AM   #5
Dead fuel pumps common?
What the OP hasn't stated is whether or not his fuel pump was replaced, based on previous posts. Or any history of the car to allow anyone a perspective of what he sees. Despite using a link about suggestions to troubleshoot a fuel issue, nothing concrete is forthcoming.
Its easy to simply suggest locating one of two areas where the ground connections are for the fuel pump, rear brake light wiring or behind the rear seat but without any more feedback as to whether or not the OP actually tried wire jumping fuel pump relay terminals 30 and 87 and following up, this thread remains a mystery............................ Specific feedback is sorely needed at this advanced troubleshooting level.
Old 03-23-2013, 09:46 AM   #6
Firestarter
Yes I have tried jumping the fuel pump relay and also tried swaping the relays with the working wiper relay.
2002 LW300 fuel tank question saturlw300 L-Series General 3 10-25-2012 10:32 AM
HELP! Intermittent Startup Problem with my 2002 LW300 Saturn Wagon stillpictures Canadian Saturn Owners 3 06-12-2012 11:33 AM
HELP ASAP! 2002 Saturn LW300 rev limit at 4k now sluggish V_dub97 L-Series Tech 5 09-15-2011 09:00 PM
If the A/C diode is reversed will compressor turn on? 2002 Saturn LW300 clean93 L-Series Tech 5 05-15-2011 07:37 PM
2002 Lw300 silverplum L-Series General 30 04-02-2002 05:23 PM
