Old 12-31-2012, 08:07 PM   #1
Firestarter
Firestarter is on a distinguished road
2002 L-Series 3.0L Wagon
Default LW 300 Cylinder 1 Missfire.
I have a Saturn LW 300 that says cylinder 1 Missfire and I have changed the spark plugs and I am thinking the next step is to change the rear coil pack. Anyone here ever have the same problem.
Firestarter is offline   Reply With Quote
Old 01-01-2013, 10:33 AM   #2
GregS&L
GregS&L is a jewel in the roughGregS&L is a jewel in the roughGregS&L is a jewel in the rough
GregS&L's Avatar
2001 L-Series 3.0L Sedan
Default Re: LW 300 Cylinder 1 Missfire.
A similar thing happened to me last spring at 96,xxx miles. A noticeable engine miss came on suddenly and would not go away. Scanner revealed code P0303 (cylinder 3 misfire). Replaced all the original plugs (it was time anyway). The miss was still there same code. None of the old plugs showed any signs of fouling. Pulled the no. 3 spark plug and detected a slight gasoline smell meaning the injector is probably ok. Replaced the 1, 3, 5 coil pack problem solved.
GregS&L is offline   Reply With Quote
Old 01-02-2013, 04:19 PM   #3
Firestarter
Did you have to reset anything to get it to register after? I changed the coil pack and it runs great but still getting service engine. Have not had the code read or anything yet. Just curiouse if I have to do anything to reset the code. I changed the plugs last spring and then changed the rear ones again this summer and finally dicided to do the coil pack today.
Old 01-02-2013, 07:56 PM   #4
GregS&L
GregS&L's Avatar
I used my code reader/scanner to clear the check engine light - did not reset anything else. I have heard that disconnecting the battery for 30 seconds or more will clear the light, but never tried it. Maybe someone can chime in on this.
help missfire on the #2 cylinder!!! gene. General Saturn Discussion 4 12-22-2010 07:33 PM
Need advice on my 98 SL, Cylinder 2 Missfire Stankdaddy S-Series General 23 11-18-2010 06:35 PM
cylinder 1 missfire saturntom1 S-Series Tech 2 11-13-2010 10:57 AM
1996 SL2 missfire on 1 and 4 cylinder pdesorm S-Series Tech 10 09-02-2009 09:22 AM
Help/Suggestions. only one cylinder missfire. Gridlocked S-Series Tech 7 08-04-2004 11:38 AM
