Old 01-21-2018, 07:55 AM   #1
dmayorgap
dmayorgap has a spectacular aura aboutdmayorgap has a spectacular aura aboutdmayorgap has a spectacular aura about
dmayorgap's Avatar
2008 VUE 3.6L
Default Engine compartment cleaning
Hi!, its ok to clean the engine compartment with a home water hose? should i take some precautions?
Thanks
David M.
Chevrolet Captiva Sport AWD V6 3.6
dmayorgap is offline   Reply With Quote
Old 01-21-2018, 05:18 PM   #2
Default Re: Engine compartment cleaning
There are always risks whenever water is introduced into the engine compartment, that's unavoidable. Potential problems can be minimized when precautions are taken.
Oh, yes! You must protect electrical connections from possible contact with water. Moisture inside of connectors can result in unusual issues arising which may impair engine and charging system performance by corrupting electrical power flow within various circuits. Additionally, false readings could be sent to the ECM and result in unnecessary check engine warnings and/or wrench light warnings. Be careful.
A general precaution with regard to the body would be to cover any painted surface near the area being cleaned - fenders, bumper, and perhaps the windshield. Dirty water over-spray bouncing off of surfaces within the engine compartment may contain some corrosive chemical elements within it which should not make contact with a painted surface.
If you go through with this, let us know how things turn out.
350K miles - Holy canolli!
Biden/Harris predictions, '21 -'25: weak economy; weakened military; increased terrorism; an emboldened RED CHINA. I fear that I will be correct. I'd rather be wrong.
Old 01-22-2018, 12:08 PM   #3
dmayorgap
dmayorgap's Avatar
2008 VUE 3.6L
Hi! thanks for your answer, besides the precautions should i take to clean the engine compartment, is it recommended to do it? or is not necessary?
Thanks
David M.
Old 01-22-2018, 01:25 PM   #4
[/QUOTE]You won't find this as a recommended service by the OEM. However, it is known that caked on greasy dirt acts as a form of insulation meaning that the engine operates at a warmer than it should otherwise. So is it wrong, or bad, to do an engine compartment cleaning? No. It's a matter of doing the cleaning well and carefully.
Old 01-23-2018, 08:49 AM   #5
atikovi
Just get a can of Gunk and go to the self service car wash. Spray down the engine bay with maybe a quarter of the can depending on much dirt and grease there is. Wait a few minutes and then using the high pressure wand, go at it but obviously don't spray directly into any electrical connectors.
Old 01-23-2018, 11:48 AM   #6
That's a great picture, atikovi! Am I wrong in assuming that the car there is yours?
If you look at the location of the OP, that person is in Ecuador. I have no idea what the likelihood is of finding a self-service car wash in that country, however, I would expect it to be low.
Old 01-23-2018, 02:34 PM   #7
atikovi
Sold that one a few months ago.
Cleaning the Engine Compartment jsnead S-Series General 23 02-10-2012 12:37 PM
NEED engine compartment cleaning edzdallas S-Series General 5 06-11-2006 07:02 PM
cleaning my Ion engine compartment jaman Ion General 8 01-06-2006 04:55 PM
Engine Compartment cleaning littlebob Miscellaneous Tech 9 07-27-2001 12:12 PM
Engine Compartment Cleaning cyberbill S-Series Tech 6 10-12-2000 12:20 PM
