Go Back   SaturnFans.com Forums > Categories > Classifieds
Old 12-28-2003, 08:15 PM   #1
jiminEcricket
jiminEcricket is on a distinguished road
Arrow d.o.h.c. head
for sale: 95' dohc cylinder head assy. this is a used head with all parts installed. ready to bolt on as is, though i would personally replace the stem seals and hand lap the valves. one cam cap has a little grind spot on the top due to the bolt rounding off. the bolt has since been replaced and as long as torque specs. are used will be fine as the caps are machined w/the head. asking 70.00 firm. thanks . eddiesterling@wmconnect.com
jiminEcricket is offline
coolant leak...head gasket, cracked head, or water pump? BRIAN41920 S-Series Tech 13 01-11-2013 04:18 PM
SOHC Alternator bracket oil puddle - head or head gasket? comanche S-Series Tech 10 09-28-2009 05:42 PM
Head gasket, head bolts and other head related foolishness… Quagmire S-Series Tech 9 09-12-2007 10:08 PM
Cracked head/blown head gasket tech HELP WITH DIAGNOSIS ferdypooh Ion Tech 7 08-16-2002 10:50 AM
question head work , head gasket leaks oil!!HELP sat92SLI S-Series Tech 5 03-26-2001 12:46 PM
