Old 09-12-2014, 03:24 PM   #1
slippage
slippage is on a distinguished road
Default 2007 vue 3.5 fuel drop issue
Hi, having an issue where fuel pressure (measured on the rail) will be right at 60 during operation and within a minute of key off drops to ~ 40. Clearly I have a leak somewhere in the fuel line. It initially presented with occasional long cranking about 2-3 months ago. Since the injectors are a challenge to get to, any advice on how to determine if it's a check valve/regulator in the fuel pump or a leaky injector without dismantling everything? There's no active codes or misfires from this, and the engine performance seems good (runs relatively quiet), but I seem to be getting somewhat lower gas mileage ~14-15mpg (100% city driving).
Currently 105K miles, New plugs done at 80k, timing belt 95k, Replaced Evap Vent Solenoid Valve 90k due to code popping up.
Thanks
slippage is offline   Reply With Quote
Old 09-12-2014, 03:47 PM   #2
RobertGary1
RobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to allRobertGary1 is a name known to all
Default Re: 2007 vue 3.5 fuel drop issue
There is a formal procedure in the FSM to test this that involved blocking parts if the system to isolate them. The most common cause is the fuel pump allowing the pressure to drain back into the tank.
Another solution is to just wait a second or so between the time you turn the key to "on" and the time you crank. It's an easy habit to learn. You can do it as you put in your seat belt, light your smoke or pop your beer (j/k).
-Robert
Tags
cranking, fuel injector, fuel pump
substantial fuel mileage drop Lepercon S-Series General 19 07-09-2014 12:14 PM
Sudden fuel economy drop - 2009 2.4L hiromasaki Aura General 20 01-22-2013 01:19 AM
High fuel pressure=mileage drop? SL2Many S-Series Tech 27 09-15-2008 02:44 PM
Drop in fuel milage... erick295 S-Series General 39 09-12-2006 09:50 PM
Fuel Economy Drop marcusa S-Series Tech 4 04-22-2005 09:17 PM
