Old 07-17-2011, 06:38 PM   #1
discslinger
discslinger is on a distinguished road
discslinger's Avatar
Default FUEL INJECTOR ORDER ON RAIL? Who knows?
Plugging along on Cylinder 2 misfire and I have removed the fuel rail on my 98 Saturn SL2 (DOHC, Automatic)
I'm going to swap # 2 fuel injector position to test for misfire. (I need to trade with #1 or #4... correct)
Which one's are which on the rail?
Thanks!!!!
The Discslinger
discslinger is offline   Reply With Quote
Old 07-17-2011, 07:17 PM   #2
Default Re: FUEL INJECTOR ORDER ON RAIL? Who knows?
Uhh...Pick one. The first 3 are 100% the same, even with the connector. #4 connector is flipped for some reason, but it still plugs into the injector the same way as the other 3.
Tags
fuel injector
Fuel Injector Location? Engine Code says clogged injector. tAURAnce_guy Aura General 4 05-19-2010 06:17 PM
Tapping Injector/Fuel Rail? AndreasChen S-Series Tech 2 03-29-2010 11:13 AM
Fuel Rail/Fuel Filter Question Growser S-Series Tech 3 08-23-2009 01:25 AM
swapped in new injectors, no fuel to fuel rail! DJboozeAlot S-Series Tech 6 06-05-2009 04:10 PM
Size of Fuel Pressure connector on fuel rail bc3tech Ion Tech 0 09-08-2006 11:15 AM
