Old 05-09-2021, 08:32 AM   #21
Default Re: 5spd Transmission problem 1998 SL2
Originally Posted by Waiex191 View Post
Heins 's website is here:
https://diyvan.com/
I thought he was done with Saturns though.
Yeah, hein sold his car years ago. In the past, he's said he would remake them if at ~10 people were interested. Not sure is he is still able and willing though
However, he also posted a quick how to. He also posted the McMaster-Carr part number somewhere for the heim joints he used
http://www.saturnfans.com/forums/sho...d.php?t=189404
He didn't make new cables. I think he always started out with jy cable sets and replaced the end joints.
Old 05-09-2021, 08:59 PM   #22
Ricketts
Ricketts is a glorious beacon of lightRicketts is a glorious beacon of lightRicketts is a glorious beacon of lightRicketts is a glorious beacon of lightRicketts is a glorious beacon of light
2000 SC1
Originally Posted by Steve4637 View Post
Thank you.
The guy who fixed it says I should get new shifter cables as he said they are worn out. He recommended I find some new cables instead of used ones from a wrecking yard. He said I also need a new clamp
Has anyone used any aftermarket cables, like those from RockAuto?
I can vouch from personal experience that Dorman cables are junk. I didn't get 10K out of them before they failed, luckily in my driveway after a 2000km trip. I put a used set of Saturn cables in from a junk yard
2000 SC1 - Bone Stock
No power windows, no power locks, no AC, no cruise control...just a good DD that has nothing to break on it
Ricketts is offline   Reply With Quote
Old 05-09-2021, 10:43 PM   #23
99% sure he reused OEM cables (dunno how much he charged, if much over $200 highly likely he bought new OEM cables). You'll have to get the die size from McMaster's listing on the joints to get the threads on the cable correct.
McMaster 6072K31 on the trans
McMaster 6072K154 on the shifter
I *think* they could all be the same joint, except 1 style has the stud in the joint rather than going over the stud on the trans or shifter.
Every single brand of aftermarket shift cables have proven to either be junk out of the box or junk within 15k miles. Some can be patched up with reinforcements where they bend or extra lube, but if you plan on keeping the car a long while you're better off with junkyard cables (just try to verify they're OEM style not aftermarket). The only change I can think of with the cables doesn't stop them from swapping any year/model/engine/trans, the firewall grommet got bolted in (squishing the firewall) sometime after '97 while it was hand-press in like any other grommet before then.
Old 05-10-2021, 08:35 AM   #24
Ricketts
2000 SC1
My 2000 Saturn cables were press in, the Dorman was bolt in. The new to me JY ones were press in. From a late 90's SL, can't recall the exact year.
Old 05-10-2021, 09:20 AM   #25
Waiex191
Waiex191's Avatar
I believe someone over at 6th Sphere custom made some cables with heim joints on the ends. They looked awesome.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 05-10-2021, 01:03 PM   #26
Steve4637
Steve4637 is on a distinguished road
Thanks for all the help.
I have one more question --- when going to find some at a wrecking yard -- which year cables are interchangeable?
My car is 98 SL2 DOHC -- which other years/models will work for me as I may have located some from a 2001?
Steve4637 is offline   Reply With Quote
Old 05-10-2021, 02:22 PM   #27
Waiex191
Waiex191's Avatar
I believe they are all the same. You could look up the PN on Rock Auto for both a '98 and a '2001. Also SOHC vs DOHC should not matter.
Bryan Cotton
Old 05-10-2021, 08:09 PM   #28
trottida
trottida's Avatar
Username is Hein and he has posts in this forum too. He sells some stuff on eBay under his van conversion company name. Here is is website.
https://diyvan.com/
Here's his post on sixthsphere and this forum ...
https://forum.sixthsphere.com/forum/...s-shift-cables
http://www.saturnfans.com/forums/sho...d.php?t=197893
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 05-11-2021, 08:38 AM   #29
Waiex191
Waiex191's Avatar
Maybe I'll make a set of cables for myself. We will see. It doesn't look super hard.
Bryan Cotton
Old 05-11-2021, 02:28 PM   #30
Thought I posted the link to ShawnV;s How To cable replacement in this thread but must have been in another thread.
http://www.saturnfans.com/forums/sho....php?p=1679808
OldNuc mentions in that thread that Saturns came from the factory with the push-in grommet at the firewall. If it is a replacement cable set (either OEM or aftermarket), it will have the the plate/stud retainer style
5spd transmission fluid sw87 S-Series General 14 02-06-2011 06:12 PM
1998 SC2 transmission problem harley2003 S-Series General 3 04-16-2010 10:00 AM
1998 Saturn SL2 Transmission problem jpoell01 S-Series Tech 7 09-04-2009 01:56 PM
1998 SL1 Auto Transmission Problem Spreck13 S-Series Tech 2 03-31-2008 01:34 PM
WTB: 5spd Transmission Madson26 Classifieds 7 08-10-2005 08:40 AM
