Old 05-05-2021, 12:58 PM   #1
cujoe_da_man
cujoe_da_man is just really nicecujoe_da_man is just really nicecujoe_da_man is just really nicecujoe_da_man is just really nice
cujoe_da_man's Avatar
Default What size clips hold the air dam under the radiator?
Anyone have pics of the push pins that hold the air dam on underneath the radiator? I went through the small collection I have and nothing fits, all too big.
I only just FINALLY figured out what that piece was as it was just laying in the trunk when I got the car and now I'm anxious to get it on
Check out my current SL1!
http://www.saturnfans.com/forums/showthread.php?t=268456
cujoe_da_man is offline   Reply With Quote
Old 05-05-2021, 01:23 PM   #2
trottida
trottida's Avatar
Default Re: What size clips hold the air dam under the radiator?
It's actually held on with springs. GM part number 21030793. 4 springs feed through and clip together in pairs . It is #11 on this diagram and you can watch this RichPin video https://www.youtube.com/watch?v=9cQfgKW64lU
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 05-05-2021, 01:28 PM   #3
Waiex191
Waiex191's Avatar
Mine is held on with 1/4-20 screws.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 05-05-2021, 01:57 PM   #4
cujoe_da_man
Springs... really? Ugh, sometimes engineers just make my brain hurt... I think I'll use a nut a bolt with some stainless fasteners.
Thanks for the info anyway!
Old 05-05-2021, 05:25 PM   #5
trottida
trottida's Avatar
Springs allow it to flex if you hit a curb or something. Fastening it in a fixed position risks breaking your air dam and/or the splash shields. I've used bungees in the same fashion however you need to change them periodically as they break down over time.
Mine has been sitting in the corner of the garage for several years now. It is functional on a GEN1 however not really required on the GEN2 and GEN3. The first generation was a bottom breather and without it the engine will be more prone to overheating.
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 05-05-2021, 06:04 PM   #6
cujoe_da_man
Eh, I'm one of those that hates to have parts laying around :P
Old 05-05-2021, 06:53 PM   #7
mattwithcats
mattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the rough
Air dam is supposed to fold up under speed....
Less wind resistance...
Pennzoil Maximum Power 0W-30, Champion COS3600...
NGK BKR6E-11 spark plugs
Old 05-06-2021, 08:36 AM   #8
bumpdraft
bumpdraft's Avatar
1998 SW2
Ions have push pins. Yesterday, I set an Ion air dam in the Recycle Bin. It sat there all day ‘cause the recyclers are suffering covert illness.
Maybe you were thinking of Ion air dams.
Old 05-06-2021, 02:07 PM   #9
cujoe_da_man
I meant the air deflector, the part that attaches to the air dam, but trottida got me the info I needed
Old 05-07-2021, 11:26 PM   #10
Zeebins
Zeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud ofZeebins has much to be proud of
Zeebins's Avatar
Is it really? might be neat to set up a GoPro to see this happening...
The only problem with the springs is that they rust pretty quickly in the salt belt and break over time. I soaked mine with WD-40 Specialist Gel Lube last fall and they still look good as new.
97 SL2, auto, 123K miles
Old 05-08-2021, 09:53 AM   #11
2NDSOUT
2NDSOUT's Avatar
1999 SL
The air dam, is really just there for air flow.
I can't tell you how many of them I removed from my cars.
Honestly- you will have better air flow for the bottom front of the engine and radiator without the air dam in place. It's really an un-needed part.
Just my thoughts.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 05-08-2021, 09:58 AM   #12
cujoe_da_man
lol, the way things are going right now, it might not matter either way. With the way the jetstream is, Michigan has been having some mighty strange weather (and pretty much everywhere else too). We are currently back to 30 degrees at night and 50 degrees by day.
Also, I need to replace the thermostat in the car as it isn't working properly anyway, so it's just dumping all the coolant through the system and super-cooling everything. Though, at the end of the day, I'd rather have a car that's overcooling than overheating
Old 05-10-2021, 12:12 PM   #13
trottida
trottida's Avatar
Over cooling will cause you grief in the longer run due to carbonization of the engine and exhaust components. You'll also experience poor gas mileage. When the engine temp reads cool the PCM increases fuel. Thermostats, ECTS and ECTS connector are all easy maintenance parts to replace to ensure best engine performance and longevity.
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 05-10-2021, 03:00 PM   #14
cujoe_da_man
Oh, I agree, I just mean in the case of ending up with a blown head gasket or warped head from overheating
I'm getting prepped to change the thermostat in the next day here. Just bought new coolant and already have the thermostat. Gotta turn the outside water on and start flushing!
Fender Retainer Clips- Size and Where? calspiff Vue General 1 01-23-2012 10:15 PM
4 pins/clips/bolts on the underside of the rear bumper that hold the facia??? 2002SaturnMan S-Series General 1 04-19-2006 10:52 PM
Newbie Question - Size of Air condenser compared to radiator? Also airbag question. 2002SaturnMan S-Series General 9 04-18-2006 09:53 AM
Fuel Rail Hold down bolt size CmonComet S-Series Tech 0 10-20-2005 01:49 PM
Doing front brake pads/rotors: torque plate bolt size and new anti-rattle clips?? Gold93SL1 S-Series Tech 2 05-16-2005 08:54 PM
